T
tommo2
Hi.
I've ordered a iScan HD from ebay and am looking to find a breakout cable to connect it to my BD701s.
The output from iscan is vga so i need a vga to BNC breakout cable.
I was all set to buy a VGA to 5 BNC cable as was suggested by someone but when i checked out the spec for the cable it said it was only compatible with 5 BNC signals (seperate H and V sync).
The pj requires RGB and composite sync (four connections)
I was led to believe that using a 5BNC cable and just not connecting the extra connector would suffice but now am not so sure.
Anyone got any ideas how best to connect to the pj???
The cable im looking at is here:
www.hdstep.com/detail.php?m_id=1026
Is there such a cable as VGA to 4BNC for pj's that require composite sync???
Thanks y'all
Thanks y'all
