Thought it might be useful to clarify how the Pioneer hard drive recorders handle aspect ratio switching, it isn't too clear in the manual and it is assumed on a DVD-R Video disc that no wide screen signal is recorded, this isn't always true, and you can have wide screen switching on DVD-Rs if you know how:
When recording to the hard drive
Wide screen signal is recorded appropriately and will switch on playback as the original source did, i.e. 16:9 adverts then 4:3 for the program.
When recording real-time to a DVD-RW VR mode disc
Wide screen signal is recorded appropriately.
When recording real-time directly to a DVD Video (DVD-R or DVD-RW in video mode)
Wide screen signal is defaulted to 4:3 regardless of the source; you will need to manually switch your TV to 16:9 for wide screen recordings. Widescreen sources will be tall and thin on 4:3 TVs.
When dubbing from the hard-drive to DVD Video
When high-speed dubbing the wide screen switching is completely preserved, so on playback from the DVD the wide screen signal is present for 16:9 sources. Note that if the source changes between 16:9 and 4:3 these will be split into separate titles on the DVD to keep to the DVD Video specification.
When dubbing real-time, for example when re-compressing to fit on a single disc, then the source will be recorded as 4:3 regardless. There is a way around this however:
1) Use a DVD-RW in VR mode, and recompress to that VR mode disc. This preserves the widescreen-switching signal.
2) Next, high-speed dub the DVD-RW VR mode disc to the hard-drive giving you a new title that is compressed to the right size for fitting on a DVD.
3) Take a DVD-R disc, and then high-speed dub this new title to it, which will preserve the wide screen switching.
So in summary, to get wide-screen switching on a DVD-R Video disc, record to the hard-drive first then high-speed dub to the DVD. Follow the steps above if you need to recompress the video on the hard-drive in order to fit onto a single disc.
Hope this helps.
Regards
Phil
Hope this helps.
Regards
Phil
