TransientWolf
Established Member
Hi all
Finally got my VP30 just before Xmas and very pleased with it in all areas, particularly the audio switching and built in lip sync. Sky+ picture quality is amazing compared to the panel alone.
Only slight problem is I have the VP30 set to output a 50hz input signal as an unlocked 59.94hz output signal to the panel. On all 50hz sources this is absolutely fine except Sky+ On Sky+ (SVideo input) the picture quality is stunning but there is jerkiness on panning across the picture - only slight but when you know its there you keep looking for it.
I am addressing the panel at native resolution (1360*768) - (Fujitsu's are 1360 rather than the quoted 1366).
If I switch to a 720p output the jerkiness goes away but the picture quality suffers as the panel starts to do some processing too. I figure it must be better to address the panel in native resolution.
I then switched the settings so that a 50hz input was output at a 50hz locked signal to the panel. Hey presto - it got rid of the jerkiness, pcture quality was good, BUT the whole picture jumped about 18 inches (yes 18 not a mistype) to the left with massive overscan. Changing the horizontal shift did not move the picture.
I am planning to get Gordon to calibrate the panel for me but was waiting for Sky Hi Def to come first. Of course taking that into the VP30 via an HDMI input may well solve the problem anyway but was hoping to improve in the meantime if anybody has any ideas.
I did think about getting a Scart RGB to RGBS adaptor and going in to the VP30 on one of the RGB + Sync inputs to see if that made a difference too.
Any ideas or anybody else who has this problem on the VP30 - thoughts welcome.
TW
TW
