AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 08-05-2003, 10:53 PM   #1 (permalink)
dolby digital sound from nokia 221t?
i cant seem to get dolby digital 5.1 sound from my nokia 221t .
i have my 221t connected to a sony strdb 780 amp using a monster coax cable.
amp is set to auto detect , but signal on amp is pcm 48 ( whatever that is ? and only in stereo. )
i can get the stereo signal to prologic 2 simply by pushing the button but i was expecting dolby digital 5.1 ?
what should i change to try get DD 5.1 from the nokia ?
or is it not possible to get DD 5.1 from the box ?
setup here ... www.ascott1.pwp.blueyonder.co.uk
F1F3R
F1F3R is offline
Old 08-05-2003, 10:58 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,105
No expert but i am sure that stereo only is transmitted. Sky+ is the only DD transmission source as far as i know.
hornydragon is offline
Old 08-05-2003, 11:10 PM   #3 (permalink)
Starburst's Avatar
Thanks: Gave 87, Got 632
That's right, only SKY digital broadcasts DD5.1 material to the UK at this time. The format is however used through out Europe so sooner or later it's got to turn up on DTT.
"The Nac Mac Feegle are, well, they’re like tiny little Scottish Smurfs who have seen Braveheart altogether too many times."
Starburst is offline
Old 08-05-2003, 11:28 PM   #4 (permalink)
that explains it then
thnx
F1F3R
F1F3R is offline
Old 08-05-2003, 11:30 PM   #5 (permalink)
nathan_silly
Posts: n/a
I would take a guess the most you'll get out of a UK DTT box is Pro-Logic.
Old 09-05-2003, 3:35 AM   #6 (permalink)
My 221t is connected via the spdif, to a Yamaha av amp, I get "prologic" as the input same as NICAM, there is rear channel information, as per the NICAM broadcast.
Regards
Steve T
9designs is offline
221t, digital, dolby, nokia, sound
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
