AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 05-05-2003, 2:35 AM   #1 (permalink)
Is the Nokia 221T sensitive ?
Is it good on low signal strength, as a Daewoo “Setpal” tuner works fine, is the Nokia as good as a "setpal" unit.
9designs is offline
Old 05-05-2003, 2:27 PM   #2 (permalink)
Fernsehman
Posts: n/a
The 221T is allegedly "almost as sensitive as the Setpal models". But the only real test is to borrow one and try it. Mine seems pretty good. BTW, it's especially important to use double-shielded cable in a weak signal area.
Fman.
Old 05-05-2003, 3:24 PM   #3 (permalink)
media guy
Posts: n/a
Setpals use a different chip that has been made for low signal strength areas but the Nokia is very good as this show
Analogue Vs. Digital Reception
Old 05-05-2003, 4:51 PM   #4 (permalink)
Good News !
Just picked up a 221T from Currys (£129), plugged it in and it found 35 TV channels and load of radio ones, I guess that’s a full house !
The signal strength meter hovers at the top of the yellow/bottom of the green. I assume this is an average of all the channels. The Setpal based Daewoo showed strength per “mux” group, which was handy, though I’m not sure how accurate it was as it read 0 on some groups but still worked ! ( I use CT100 through out, with one break for the booster in the loft)
Picture quality seems about the same.
Sound though is very good, I’m using the PCM digital out to my Yamaha DSPE800.
Software version is current level as per the Nokia website ( 1.1.2) and the menus seems to work nicely.
Time will tell if I loose signal with weather changes etc.
All in all pretty happy, just need some decent programmes or films to come on now.
Steve T
9designs is offline
Old 08-05-2003, 10:13 PM   #5 (permalink)
DJM
Thanks: Gave 1, Got 1
the 221t signal strength meter is per channel. Look at a BBC channel, then compare the strength to an ITV channel. You will probably see the difference then.
DJM is offline
221t, nokia, sensitive
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
