AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 18-04-2003, 12:41 AM   #1 (permalink)
Thanks: Gave 2, Got 14
Nokia mediamaster
Hi im using a Nokia mediamaster 9850t. When i was subscribing to OnDigital i could get all the channels really well with the upgraded ariel. Now i can only receive the BBC channels ,i cant get ITV1,ITV2, CH4 and CH5 just a red dot . Nothing has changed and the ariel hasnt moved. I get my signal from the Dover (Hougham) transmitter. Anyone have the same problem
steve
lazysod is offline
Old 18-04-2003, 1:38 AM   #2 (permalink)
I have a Nokia 9850T and it often shows a red dot on the SDN channels. Make sure your aerial is plugged in right and perhpas move it around a little, if that fails i think it could be a new rooftop aerial you need or perhpas its damaged. Im sure its just the way you move your tv or somin happens to mine alot
PhilipVass is offline
Old 19-04-2003, 12:50 AM   #3 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,104
I am using a nokia at my girlfriends house and it works fine on all channels! Do as above and try a full retune just in case they have moved the channels around since last time!
hornydragon is offline
Old 19-04-2003, 1:27 AM   #4 (permalink)
Checked ariel with meter ,strong signal. All cabling is new and i,ve reset and scanned all channels. I think its the Ashford area served by the Hougham transmitter that is the problem
http://www.swgm.btinternet.co.uk/hcpc.htm
lazysod is offline
Old 19-04-2003, 2:48 AM   #5 (permalink)
Fernsehman
Posts: n/a
"Ariel" is a biological washing powder!
I bet it works much better with an "aerial".
Old 19-04-2003, 1:24 PM   #6 (permalink)
HA HA, not at the moment it doesn,t i would be better off with comfort
lazysod is offline
Old 20-04-2003, 3:54 PM   #7 (permalink)
Fernsehman
Posts: n/a
Out of interest, my 9850T shows the following information:-
Technical Information
Manufacturer data[FONT=courier new]
hardware version....... 00 00 03 07
software version....... 00 01 42 09
manufacturer update.... 00 00 00 00
api version............ 00 12 27 04
run version............ 00 07 03 0b
run update version..... 00 00 00 00
[/FONT]
Old 20-04-2003, 5:56 PM   #8 (permalink)
Cheers mate, heres mine
Manufacturer data
hardware version....... 00 00 06 07
software version....... 00 49 06 09
api version............ 00 12 3c 04
run version............ 00 07 03 0e
lazysod is offline
Old 20-04-2003, 8:18 PM   #9 (permalink)
Fernsehman
Posts: n/a
Hmm, I wonder what all those numbers mean!
Who has the oldest software?
FWIW my box works fine. :-)
Old 20-04-2003, 11:20 PM   #10 (permalink)
Thanks: Gave 31, Got 206
Try changing the RF output frequency. It might be causing a conflict with initial reception.
Mr.D is offline
mediamaster, nokia
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
