AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 15-04-2003, 2:19 AM   #1 (permalink)
BTH86
Posts: n/a
Panasonic Digibox TU DB31
Moving to an apartment where I can not have my sky dish placed on wall. Can I use my panasonic digibox as a freeview digibox using the aerial ? I have cancelled the sky subscrption. Can I carry on using the card or will I need a free view card if I can still use this box. Or do I have to get rid of it and just go out and purchase a freeview digi box ? thanks
Old 15-04-2003, 3:12 AM   #2 (permalink)
Your digibox will not work without a dish. You will need a freeview box or an ex On Digital box to receive freeview channels through the aerial. I can offer you a Phillips On Digital box in exchange for your Panasonic digibox if this would be of any help to you.
peter-d-w is offline
Old 15-04-2003, 11:08 PM   #3 (permalink)
Thanks: Gave 11, Got 11
Cool panasonic DIGIBOX
A panasonic TSB31 digibox is a prized possession and is worth a lot more than a FREEVIEW box. A freeview box can be had brand new for £99 - £140. Look on EBAY and check out the price of your Pana and the small ads in local paper. U should be quids in.
gb---
gbmitie is offline
Old 17-04-2003, 12:42 AM   #4 (permalink)
Fernsehman
Posts: n/a
I suspect it's actually a Panasonic TU-DSB31.
If you advertise it for sale, at least make sure you copy this model number correctly.
db31, digibox, panasonic
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
