Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
Latest AVForums Movie Reviews
Music Man, The Blu-ray ReviewUgly Truth, The Blu-ray ReviewEmpire Of The Ants - Original Motion Picture Soundtrack CD ReviewThe Toolbox Murders Blu-ray ReviewDungeons & Dragons: Wrath of the Dragon God Blu-ray Review
The Book of Eli - Original Motion Picture Soundtrack CD ReviewInvention of Lying, The Blu-ray ReviewSmokin' Aces 2: Assassins' Ball Blu-ray ReviewDorian Gray Blu-ray ReviewL'armée du crime Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Philips CRT manual tuning help danning CRT Televisions 14 09-04-2008 8:07 AM
need help with manual tuning swerv Satellite TV 2 13-01-2008 2:09 AM
Sony RDR-HXD710 Manual Tuning?? Cunning DVD and Blu-ray Recorders and Media 2 04-02-2006 2:44 PM
Help with Hotbird FTA channels AOD Satellite TV 4 09-08-2003 7:31 PM
Old 16-05-2008, 12:05 PM   #1 (permalink)
Manual tuning of channels for Hotbird
I have a GBSat Digital Receiver that is currently pointing to the hotbird satellite at 13 degrees east (receiver is around 8 yrs old).
Picture quality of the channels is excellent. However, some of the free to air channels are missing after doing a full re-scan. I specifically want to receive TVE International Europe. I’ve had a look on the internet and it says this station is at 11785H/27500 3/4.
Could someone explain how I would manually add this channel to my GBSat digital receiver and explain what the 11785H/27500 3/4 means? A couple of website show several channels on this frequency – e.g. Canal 24 Horas, R1, TVE International Europe – so how would I select only TVE International Europe rather than any of these others?
It would help immensely if someone can find a website that lets you download above info, e.g. as an excel file – the eutelsat website is in this format, but as per above shows multiple channels on one frequency: e.g 11785H/27500
Anyone’s help would be gratefully appreciated.
harveyphd is offline   Reply With Quote
Old 16-05-2008, 8:17 PM   #2 (permalink)
Chris Muriel's Avatar
Thanks: Gave 238, Got 425
Re: Manual tuning of channels for Hotbird
11785H/27500 3/4
11785 is the frequency of the transponder or multiplex in MHz.
Some receivers will want this in GigaHertz - 11.785 GHz.
H means horizontal polaratiy or polarisation.
27500 is the Symbol Rate (in kiloymbols per second).
3/4 is the FEC or "Forward Error Correction" rate.
To get a specific channel in the mux with most receivers, you enter the above parameters and hit "tune" , "find", "scan" or similar.
The box should them dispaly a channel list for you to select from - i.e. the channels it found on the multiplex that corresponds to the 11785H/27500 3/4 settings that you entered.
Other receivers may respond by asking for a Program ID or PID. There are separate PIDs for the video and audio channels and they are lsited at
http://www.lyngsat.com/hotbird.html and simialr sites if needed.
Chris Muriel, Manchester
Chris Muriel is online now   Reply With Quote
Old 22-05-2008, 10:57 AM   #3 (permalink)
Does anyone know of a Free-to-Air HD on Hotbird please?
mm218 is offline   Reply With Quote
Old 22-05-2008, 11:45 AM   #4 (permalink)
Thanks: Gave 2, Got 4
Originally Posted by mm218 View Post
Apparently Eurosport have a HD promo on HB7 11,278V 27500 2/3 that is listed on Lyngsat as clear. That's all on Hotbird I'm afraid.
Healer is offline   Reply With Quote
Old 22-05-2008, 12:21 PM   #5 (permalink)
Many thanks Healer!
channels, hotbird, manual, tuning
Copyright © 2000-2010 M2N E. & O. E.
