Humax HDCI 2000 - update and download problems
Old 16-03-2008, 10:55 PM   #1
2,596, Level: 11
Points: 2,596, Level: 11 Points: 2,596, Level: 11 Points: 2,596, Level: 11
I have been trying to download software update via download program WDN4OAK.
First I bought a usb A to A lead to connect to my HDCI2000. Didn't work .
Then I found out usb isn't enabled on this model. Strange this when this is 2008 and hardly any new pc's or laptops have a serial port, all have usb. !!
Next I bought a usb to serial adaptor and a null modem rs232 lead.
Windows xp automatically installed the usb to serial adaptor. So I thought great, I can download via WDN4OAK and update Humax. But no, the WDN4OAK program still cannot 'see' the usb to download. All it sees is com port 1 thro to 4. I was hoping the adaptor would create an interface to 'see' the usb to download to HDCI 2000. Either I am daft as a brush, very unlucky or it just ain't going to work. [/FONT]
I have all but given up ! Can anybody help !
Old 17-03-2008, 6:21 PM   #2
2,263, Level: 11
Points: 2,263, Level: 11 Points: 2,263, Level: 11 Points: 2,263, Level: 11
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Thanks: Gave 0, Got 2
Re: Humax HDCI 2000 - update and download problems
You need to be using a "Null Modem" cable. The Rx & Tx pins are crossed over in the cable. See cable details at Humax site downloads.
http://www.humaxdigital.com/HCSA/
Ken H
Old 17-03-2008, 6:31 PM   #3
15,354, Level: 29
Points: 15,354, Level: 29 Points: 15,354, Level: 29 Points: 15,354, Level: 29
Thanks: Gave 18, Got 1,045
Ken H
The OP already has by the sounds of it
"Next I bought a usb to serial adaptor and a null modem rs232 lead."
He'll need to use an adaptor as the PC/Laptop hasn't a serial port.
Vista can sometimes give problems with these adaptors and if the drivers weren't supplied help can usually be found on the net
Old 18-03-2008, 6:02 PM   #4
2,263, Level: 11
Activity: 0.6%
Sorry overlooked that a null modem cable was being used, agreed the Usb adaptors can cause problrms with some software.
Ken H
