Astra channels
Old 12-03-2008, 11:33 AM   #1
7,014, Level: 19
Points: 7,014, Level: 19 Points: 7,014, Level: 19 Points: 7,014, Level: 19
Thanks: Gave 106, Got 125
Astra channels
Ive got 2 tuners both on the astra satellite...... i seem to be missing 2 channels on one tuner that i have on the other tuner these are:
RPTi (portuguese channel)
RUS-ORTi channel 1 (russian channel)...
can anyone work out why i maybe be missing these, also what channel number are they so i can have a look for them via numerical ordering as opposed to alphabetical
Old 12-03-2008, 12:44 PM   #2
6,909, Level: 19
Points: 6,909, Level: 19 Points: 6,909, Level: 19 Points: 6,909, Level: 19
Thanks: Gave 87, Got 152
Re: Astra channels
It could be that the one box has a more sensitve tuner in it than the other, and the reception might not be brilliant, which is why it shows on one tuner, but not the other?!
Old 12-03-2008, 12:55 PM   #3
7,014, Level: 19
Re: Astra channels
god i hope not...... we bought this PVR at work because our DVD + Vid recorder was unreliable
Old 12-03-2008, 1:43 PM   #4
7,014, Level: 19
Re: Astra channels
sorry ive said they're on astra, they're not, they're on hotbird.
Old 13-03-2008, 11:47 AM   #5
6,909, Level: 19
Re: Astra channels
maybe if you let us know which receivers both are, people could help...
But I've got 2 receivers, one DM500 and one TM5400. On the TM5400 I get a signal of 96% on Hotbird, on the DM500 I get 88-90%. I've read that the TM5400 has a more sensitive tuner, hence I guess the better reception.
You might also probably do with a bigger dish, or checking that your dish is correctly aligned. Maybe even try skewing the lnb to ensure you get best signal poss...
Old 13-03-2008, 1:38 PM   #6
17,819, Level: 32
Points: 17,819, Level: 32 Points: 17,819, Level: 32 Points: 17,819, Level: 32
Activity: 17.9%
Activity: 17.9% Activity: 17.9% Activity: 17.9%
Thanks: Gave 12, Got 917
Re: Astra channels
Are these two tuners in the same receiver?
If so you may have a worse connection (or even cable) on one input than the other. Try switching off at mains and swapping the lnb cables over.
Channel numbers mean absolutely nothing on most receivers as you usually have the ability to reorder channels or delete them as you see fit.
