| Re: help for a baffled HD freeSat buyer
Freesat PVR receivers are unlikely to support motorised satellites, as they will need to permanently point at 28.2/28.5 to receive EPG information (such as schedule changes etc.) - which wouldn't be possible if they were fed from a motorised dish that could move to other satellites. I suspect it is unlikely they will support multiple LNBs or multiple dishes as well initially - I suspect the first generation freesat boxes will, like Sky boxes, be designed as single dish, single LNB (though Quad/dual output) devices designed to be just pointed at one satellite and forgotten about.
Thus if you want a full freesat box (with PVR and freesat EPG support) AND Thai TV from a different satellite, you may be best off thinking of two boxes and two dishes (or possibly a single dish with two LNBs, one feeding the freesat box, one the receiver for Thai TV)
If, however, you don't want the freesat EPG or PVR facilities then other receivers with dual dishes, motorised dishes etc. would be an option.
