Tecnomate 5400 - How to set up hard drive
Old 29-02-2008, 4:11 PM   #1
2,691, Level: 12
Points: 2,691, Level: 12 Points: 2,691, Level: 12 Points: 2,691, Level: 12
Thanks: Gave 1, Got 0
Hello. I have a techmonate 5400 receiver which has a USB output. I have tried connecting a hard drive via the usb socket; the usb connection is recognised and then I get an error message. I am assuming I have to put some software on the hard drive? I went onto the technomate web page to have a look. There were two software updates. I downloaded them but couldn't find out what they were as then I extracted the file, my computer says that the file type is not known. Can anyone help?
Thanks in advance.
Old 01-03-2008, 7:06 PM   #2
alibecks's Avatar
1,829, Level: 9
Points: 1,829, Level: 9 Points: 1,829, Level: 9 Points: 1,829, Level: 9
Thanks: Gave 0, Got 3
Re: Tecnomate 5400 - How to set up hard drive
you have to format your HDD by FAT32 than conect your HDD to TM
Samsha (02-03-2008)
