Missing Satellites!!
Old 26-02-2008, 8:51 PM   #1
3,173, Level: 13
Points: 3,173, Level: 13 Points: 3,173, Level: 13 Points: 3,173, Level: 13
I have just set up a technomate 6900 and motorised satellite dish. I could not find a satellite so called out a satellite man!!!
He found me Astra2/eurobird, astra 1d3a and astra 1. I was happy to see these sats after all my struggling but now I am wondering why I can not get other preprogrammed satellites such as Thor and Hotbird?
Any ideas or will I not get all of the programmed ones.
tony
Old 26-02-2008, 9:01 PM   #2
bob1's Avatar
14,109, Level: 28
Points: 14,109, Level: 28 Points: 14,109, Level: 28 Points: 14,109, Level: 28
Thanks: Gave 34, Got 145
Re: Missing Satellites!!
Maybe Mr Bush shot the wrong one down last week.
Sounds like its not setup correctly ,if the dish isn't following the arc of the satellites it might pick a few of the close grouped ones but as you move round it will be going off.
I'm sure one of the experts will give you a better answer as i'm only used to a fixed dish system.
Old 26-02-2008, 9:11 PM   #3
3,173, Level: 13
I'll be shot down if I don't get the wife some other channels after spending £500 and pulling down the sky hd!!!
Old 27-02-2008, 9:02 PM   #4
4,422, Level: 15
Points: 4,422, Level: 15 Points: 4,422, Level: 15 Points: 4,422, Level: 15
Thanks: Gave 1, Got 5
get the satellite man back & tell him to do the job correctly.
Depending on where you are in the country & the size of your dish, you can possibly pick up
Astra's, Eurobird, Hotbird, Thor, Sirus, eutelsat, turksat, hispasat
Old 27-02-2008, 11:26 PM   #5
4,970, Level: 16
Points: 4,970, Level: 16 Points: 4,970, Level: 16 Points: 4,970, Level: 16
Thanks: Gave 37, Got 65
Good luck in replacing that, because you wont, how ever many satellites you get.
Old 27-02-2008, 11:32 PM   #6
thfccambs's Avatar
32,083, Level: 43
Points: 32,083, Level: 43 Points: 32,083, Level: 43 Points: 32,083, Level: 43
Activity: 9.1%
Activity: 9.1% Activity: 9.1% Activity: 9.1%
Thanks: Gave 540, Got 1,116
Are you sure?
Old 28-02-2008, 1:05 AM   #7
Chris Muriel's Avatar
15,699, Level: 30
Points: 15,699, Level: 30 Points: 15,699, Level: 30 Points: 15,699, Level: 30
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 510, Got 629
To see how a polar mount should be adjusted , look at the diagram near the bottom of this page :
http://www.geo-orbit.org/sizepgs/tuningp4.html
Chris Muriel, Boston, Massachusetts (normally Manchester, UK)
Old 29-02-2008, 10:58 AM   #8
17,819, Level: 32
Points: 17,819, Level: 32 Points: 17,819, Level: 32 Points: 17,819, Level: 32
Activity: 17.9%
Activity: 17.9% Activity: 17.9% Activity: 17.9%
Thanks: Gave 12, Got 917
Originally Posted by hunts1uk View Post
Are you sure?
Free and legally you will not ... yet.
Old 29-02-2008, 1:34 PM   #9
3,173, Level: 13
Gave in and got a professional. He remounted dish above roof eaves on a pole, realigned and tuned in to all preprogrammed sats on the 6900 box. £100 and loads a channels!!!
I connected a hard drive to the technomate but it is no Sky+. Had to give in and get minimum Sky package re instated. I can not believe how much the whole family takes Sky+ for granted and miss it when its gone!!!!!!!
