Satellite signals in Norway
Old 25-02-2008, 8:09 PM   #1
2,723, Level: 12
Points: 2,723, Level: 12 Points: 2,723, Level: 12 Points: 2,723, Level: 12
We are thinking of buying a house in North Norway and I would like to understand which English language satellite channels are likely to be available (...hence how important a clear southern horizon is for house location in this mountainous area) - in particular is it possible that UK Freesat will be available?
I understand that Freesat will go out from Astra at 28.2° East and Eurobird at 28.5° East. Astra 2D seems very local to the UK but we may get it with a very large dish?
However the Eurobird 1 footprint here looks very possible. Does anyone know if Freesat is likely to go out on this footprint?
Also I am assuming that TV technologies in Norway and UK are identical - True?
Old 25-02-2008, 9:55 PM   #2
2,643, Level: 11
Points: 2,643, Level: 11 Points: 2,643, Level: 11 Points: 2,643, Level: 11
Thanks: Gave 6, Got 5
Re: Satellite signals in Norway
if you put your address in here it should give you some guide under the satellites tab.
http://www.dishpointer.com/
Old 26-02-2008, 7:46 AM   #3
15,354, Level: 29
Points: 15,354, Level: 29 Points: 15,354, Level: 29 Points: 15,354, Level: 29
Thanks: Gave 18, Got 1,045
Only one reception report here I'm afraid
http://www.astra2d.com/norway.htm
and that was with a Dreambox which don't have the most sensitive of tuners AFAIK
From another site
"Sweden, Norway & Denmark
Sky TV reception is possible in Scandinavia but for BBC channels a satellite dish size of 1.2m - 1.8m is recommended in Oslo, Norway and 1.5m in Stockholm, Sweden. Northern Sweden and Norway will need a large dish size of 2.4m. For Denmark, the recommended satellite dish size for Sky TV reception is ~ 1.3m."
Also check here for Norway
http://homepage.ntlworld.com/de.sullivan/range.htm
Old 26-02-2008, 9:04 AM   #4
6,214, Level: 18
Points: 6,214, Level: 18 Points: 6,214, Level: 18 Points: 6,214, Level: 18
Activity: 8.3%
Activity: 8.3% Activity: 8.3% Activity: 8.3%
Thanks: Gave 161, Got 91
Satellite/tv technology is the same. You`re right that you`d need a very big dish to get Astra2d, not seen what satellite or beam Freesat`s going on yet.
You will find that Canal Scandinavia shows a lot of English language stuff though, they tend to leave the original soundtrack alone and add subtitles rather than dubbing, and the film channels all have an english soundtrack.
