cams/cards fpr fortec passion receiver
Old 23-02-2008, 5:27 PM   #1
3,673, Level: 14
Points: 3,673, Level: 14 Points: 3,673, Level: 14 Points: 3,673, Level: 14
Thanks: Gave 17, Got 0
hi
just ordered one and being totally new to this could i ask which cards or cams do i need for this model to watch live and legal premiership matches.
would also like access to newish movies as well.
i only have a standard sky dish with no motor.
thanks for any help !!
Darren
Old 23-02-2008, 7:37 PM   #2
miltsharman's Avatar
3,046, Level: 12
Points: 3,046, Level: 12 Points: 3,046, Level: 12 Points: 3,046, Level: 12
Thanks: Gave 18, Got 8
Re: cams/cards fpr fortec passion receiver
i got a nagra cam on e bay and it seems to be working but as i have not got my sky card yet I cannot say for sure
Old 23-02-2008, 8:26 PM   #3
17,829, Level: 32
Points: 17,829, Level: 32 Points: 17,829, Level: 32 Points: 17,829, Level: 32
Activity: 16.6%
Activity: 16.6% Activity: 16.6% Activity: 16.6%
Thanks: Gave 12, Got 917
Sky will not work in a Nagra CAM only a Dragon, TRex or Diablo CAM BUT you will still need a Sky box to activate the card in and keep the card in it overnight every 4 weeks so that the card gets the "keep alive" signal.
Old 23-02-2008, 8:29 PM   #4
17,829, Level: 32
Activity: 16.6%
Originally Posted by mackem1966 View Post
hi
Darren
Without realigning the dish and possibly fitting a larger dish (depending what pay packages you want to view) your only options are Sky or Setanta and realigning your dish would lose the channels you get on your Sky box.
