How do I get a satellite dish in my block of flats?
Old 13-02-2008, 12:00 PM   #1
4,771, Level: 16
Points: 4,771, Level: 16 Points: 4,771, Level: 16 Points: 4,771, Level: 16
Thanks: Gave 133, Got 61
Angry How do I get a satellite dish in my block of flats?
I wonder if anyone has any first hand or legal experience in this matter.
I live in a massive block of flats, where the managing company flatly refuses individual satellite dish installation for "aesthetic" reasons. They are allegedly looking for installation of a shared dish for Sky in the roof, but claim that it is difficult, expensive, etc. Ideally I would like my own dish to receive international channels of my choice, but would settle for Sky.
There is actually a European Commission ruling showing they have no right to prohibit access to satellite TV, but obviously getting to the European Court might be a bit time-consuming and expensive! (I am happy to email the document to anyone)
This must be a common problem, how do others get round it?
Old 13-02-2008, 1:49 PM   #2
2,151, Level: 10
Points: 2,151, Level: 10 Points: 2,151, Level: 10 Points: 2,151, Level: 10
Thanks: Gave 42, Got 40
Re: How do I get a satellite dish in my block of flats?
i think sky can set up a sharing facility into blocks of flats i would have a look on their website for more details
Old 13-02-2008, 2:17 PM   #3
4,771, Level: 16
Thanks, they are allegedely looking into it, but claim it is too expensive to pursue...
Old 13-02-2008, 2:50 PM   #4
12,548, Level: 26
Points: 12,548, Level: 26 Points: 12,548, Level: 26 Points: 12,548, Level: 26
Thanks: Gave 13, Got 372
It usually costs £150+ per dwelling. All they need do is get agreements from enough tenants to cover the total cost.
Old 13-02-2008, 2:52 PM   #5
Toasty's Avatar
11,034, Level: 25
Points: 11,034, Level: 25 Points: 11,034, Level: 25 Points: 11,034, Level: 25
Activity: 11.5%
Activity: 11.5% Activity: 11.5% Activity: 11.5%
Thanks: Gave 342, Got 375
I believe I've seen sky adverts touting at least 4 people to sign up to make it a gower.
Old 13-02-2008, 3:25 PM   #6
Oggie's Avatar
20,578, Level: 34
Points: 20,578, Level: 34 Points: 20,578, Level: 34 Points: 20,578, Level: 34
Activity: 10.5%
Activity: 10.5% Activity: 10.5% Activity: 10.5%
Thanks: Gave 1,160, Got 438
have the same problem mate, i feel for you !!
Old 13-02-2008, 3:27 PM   #7
4,771, Level: 16
Thanks guys, the problem is that the standard option is for up to 48 flats and 3 floors, my block is more than twice as big which makes it more expensive and requires 3 dishes, which those *£"#$%^ managing agents are not allowing.
Anyone tried to explore the legal avenue in a similar situation?
Old 14-02-2008, 8:24 AM   #8
2,825, Level: 12
Points: 2,825, Level: 12 Points: 2,825, Level: 12 Points: 2,825, Level: 12
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
Thanks: Gave 6, Got 4
do you have any form of balcony?? you could try the super mini dishes?? i cant remember the name but they are about 30cm and have the LNB built into the centre of the dish.
Old 14-02-2008, 2:37 PM   #9
17,829, Level: 32
Points: 17,829, Level: 32 Points: 17,829, Level: 32 Points: 17,829, Level: 32
Activity: 16.6%
Activity: 16.6% Activity: 16.6% Activity: 16.6%
Thanks: Gave 12, Got 917
You mean the Multimo, here
http://www.satcure.co.uk/accs/page17.htm#multimo
40cm in diameter so only just smaller than a Sky minidish in diameter
Old 14-02-2008, 4:07 PM   #10
6,221, Level: 18
Points: 6,221, Level: 18 Points: 6,221, Level: 18 Points: 6,221, Level: 18
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 162, Got 91
Do you have any windows facing the right direction, I got sky successfully through a non double glazed window with 60cm dish for a while - obviously signal quality suffers and not the most aesthetic of solution, but might work.
Old 15-02-2008, 9:36 AM   #11
flashgordon1952
Posts: n/a
again yu need the permission of the landlord. i cant see its worth the aggro of haveing the dish inside.
Old 15-02-2008, 12:50 PM   #12
4,771, Level: 16
Thanks again to all, I think an indoor dish is too much of a hassle in my relatively small flat, although the Multimo is tempting.
The balcony idea is something I thought of, but a tiny balcony that I have access to is specifically stated in my lease to belong to the landlord, not me ! I could put the dish out and see if anyone notices, but at some point some idiotic neighbour is bound to report me.
Old 15-02-2008, 8:18 PM   #13
Omega's Avatar
1,759, Level: 9
Points: 1,759, Level: 9 Points: 1,759, Level: 9 Points: 1,759, Level: 9
Thanks: Gave 4, Got 12
Sorry to hear that. I've got a Sky dish feed into my flat but that was only because the agents were having so much trouble with people putting up dishes without permission they finally caved in and paid for a communal dish to be put up.
Any dish permanently fixed to the building even your balcony is likely to be in contravention of lease regulations etc so they could ask you to remove it. If you know what you're doing you could probably mount it on a portable pole stand or something... but you'd need to know you're facing in the right direction for the satellite. If it's round the other side of the building you're not going to get any signal.
Old 15-02-2008, 9:37 PM   #14
capitalP
Posts: n/a
do you know if HD sky is still available in blocks of flats? I am moving into a modern development, built in 2000.
Old 16-02-2008, 11:55 AM   #15
4,771, Level: 16
I wish my neighbours were like yours! Nobody here seems prepared to stand up to the managing agents. They are meant to be getting new quotes, if nothing happens I may look into directions etc, thanks
Old 24-02-2008, 8:12 PM   #16
15,822, Level: 30
Points: 15,822, Level: 30 Points: 15,822, Level: 30 Points: 15,822, Level: 30
Thanks: Gave 583, Got 289
Have you considered something such as an LX2000?
http://cpc.farnell.com/SE00465/aeria...equestid=57868
proux (25-02-2008)
Old 24-02-2008, 8:32 PM   #17
lloydsmart's Avatar
2,499, Level: 11
Points: 2,499, Level: 11 Points: 2,499, Level: 11 Points: 2,499, Level: 11
Thanks: Gave 61, Got 21
I have a similar problem. My block actually has a communal dish that works great, but I have Sky+ (actually about to upgrade to HD), so I need two feeds, which I can't get. These portable dishes look nice, but a bit expensive. Any more ideas?
Old 25-02-2008, 1:26 PM   #18
4,771, Level: 16
I'll keep it in mind, thanks, although still probably wouldnt get away with it for long!
Waiting for the possibility of a communal dish after a new survey by sky again...
Old 25-02-2008, 1:27 PM   #19
4,771, Level: 16
Lucky you! Let's see if our horrible managament company and inept residents association finally sort one out...
Old 25-02-2008, 4:59 PM   #20
3,270, Level: 13
Points: 3,270, Level: 13 Points: 3,270, Level: 13 Points: 3,270, Level: 13
Thanks: Gave 3, Got 3
Question Re: How do I get a satellite dish in my block of flats?
http://cpc.farnell.com/SE00590/aeria...BRANDED-488110
proux (26-02-2008)
Old 06-01-2011, 1:37 PM   #21
EU ruling document
Dear Proux,
Please would you send me a copy or a link to the Eu Commission document you referred to about not being able to ban access to Satellite TV.
John
Old 06-01-2011, 1:39 PM   #22
Document please
Would you send me a copy of the document, or a link
John
Old 06-01-2011, 2:25 PM   #23
70,195, Level: 64
Points: 70,195, Level: 64 Points: 70,195, Level: 64 Points: 70,195, Level: 64
Activity: 99.8%
Activity: 99.8% Activity: 99.8% Activity: 99.8%
Thanks: Gave 1,258, Got 3,020
Award-Showcase
Welcome to AVF.
Proux is still around but may not be looking into this sub-forum for old threads.
Old 07-01-2011, 10:59 AM   #24
EU directive
Thanks, do you have a way to contact him for me?
Old 07-01-2011, 11:15 AM   #25
15,354, Level: 29
Points: 15,354, Level: 29 Points: 15,354, Level: 29 Points: 15,354, Level: 29
Thanks: Gave 18, Got 1,045
If you're able to, use the PM system.
Click on his name and choose the option "Send a private message"
Old 07-01-2011, 11:22 AM   #26
17,829, Level: 32
Activity: 16.6%
Wink
Dear Proux,
John
The EU directive he is referring to is the "Television sans frontieres" ( see here - http://europa.eu/legislation_summari.../l24101_en.htm) and the main problem is that EU directive only stops blocking of FTA transmissions - it also has provisos giving owners of properties and local authorities (via planning regulations etc) the rights to limit the number (total 2 on any one building in the UK) or totally forbid or restrict their siting (in conservation areas or on listed buildings. So many people misquote these directives as giving anyone the right to install a dish anywhere which they do not.
So basically there is no regulation or directive EU or UK that gives anyone the absolute right to install a satellite dish permanently affixed to any building without permission from the owner of the building and the local council if planning permission is required. With DSO approaching completion across the UK over the next year or so councils will more than likely start applying the planning permission requirements more strictly.
Old 07-01-2011, 1:03 PM   #27
Thanks, If he had a PM option I would not have asked the question
Old 07-01-2011, 2:31 PM   #28
70,195, Level: 64
Activity: 99.8%
Award-Showcase
My answer to the question would have been the same "if you're able to" - we don't know that.
Try looking at his profile to see what other Contact Info he has, if any.
Old 07-01-2011, 4:32 PM   #29
15,354, Level: 29
But he has (see attached) however you may not have enough privileges yet hence the "if"
How do I get a satellite dish in my block of flats?-pmproux.jpg   How do I get a satellite dish in my block of flats?-pm2.jpg
Old 08-01-2011, 11:17 AM   #30
4,771, Level: 16
hello, i think the question has been answered, and I can't find the document anyway as it was too long ago. I remember that some restrictions were mentioned, but my feel was that it was very much supportive of everyone's right to information
BTW I do receive pm's, as long as the sender is allowed to send them as already mentioned
logiciel (08-01-2011)
