This HD Satellite Free-To-Air Kit anygood
Old 07-02-2008, 12:52 AM   #1
12,738, Level: 27
Points: 12,738, Level: 27 Points: 12,738, Level: 27 Points: 12,738, Level: 27
Thanks: Gave 34, Got 214
I am after a cheap free to air satellite kit also would like to be able to pickup bbc hd would this kit do the job.
http://www.maplin.co.uk/Module.aspx?...222155&doy=7m2
Also what are the channels this unit would pick up is there a list anyware and is there anything else i would need to get going.
thanks.
Old 07-02-2008, 6:36 AM   #2
Conspicuous Member
21,528, Level: 35
Points: 21,528, Level: 35 Points: 21,528, Level: 35 Points: 21,528, Level: 35
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 4, Got 1,393
Re: This HD Satellite Free-To-Air Kit anygood
Would it not be better to wait till Freesat officially launches (Spring 2008) and get one that is fully compatible and will also support any EPG that is sent out.
Old 08-02-2008, 9:35 AM   #3
6,909, Level: 19
Points: 6,909, Level: 19 Points: 6,909, Level: 19 Points: 6,909, Level: 19
Thanks: Gave 87, Got 152
Should be able to pick up all of the free to air hd channels available... As for the available channels, here is a list of all channels available which are High Def, but only the ones which state Clear in the "Encryptions" column would be receivable.
To be honest, I would say you're best off waiting till freesat appears which will give a high-def version, and would probably see release of more high-def channels...
Other problem with hi-def receivers is the 4:4:2 or whatever it is (sure someone who knoews more than me will be here to post soon enough ) will probably cause some headaches along the lines...
Old 08-02-2008, 12:40 PM   #4
12,738, Level: 27
Ok cheers guys i think i will wait for freesat then.
