Fortec Passion-can't alter aspect ratio.
Old 06-02-2008, 2:51 PM   #1
2,648, Level: 11
Points: 2,648, Level: 11 Points: 2,648, Level: 11 Points: 2,648, Level: 11
Hi all,re Fortec Passion problem or confusion.
New to HD and using HDMI. When I watch scaled SD channels ,I can't alter the aspect ratio.TV is Sony Bravia 40".Sky RGB scart and DVD component can be changed on the tv remote.Also if I use an RGB scart to HDMI scaler box I can alter the aspect ratio.Is there any way I can watch SD channels in 4:3 or 14:9 through the HDMI input ?
Cheers Chrisg4gpu.
Old 17-02-2008, 1:17 AM   #2
4,694, Level: 16
Points: 4,694, Level: 16 Points: 4,694, Level: 16 Points: 4,694, Level: 16
Re: Fortec Passion-can't alter aspect ratio.
I cannot give you the answer but as I am about to buy one soon I would ask what ratio you ARE able to view at?
Can you also tell me if that receiver can drive a motorised dish?
Rather oddly Maplins offer the HD receiver with a fixed small dish and an SD receiver with a larger motorised dish!
Tony
PS I wonder whay I am a new member when I joined nearly three years ago!
Old 17-02-2008, 1:22 AM   #3
JayCee's Avatar
30,393, Level: 42
Points: 30,393, Level: 42 Points: 30,393, Level: 42 Points: 30,393, Level: 42
Activity: 38.2%
Activity: 38.2% Activity: 38.2% Activity: 38.2%
Thanks: Gave 168, Got 1,190
It's because this is only your 3rd post.
Old 17-02-2008, 7:33 AM   #4
2,648, Level: 11
Agile...Hi,
No motorized control.
Can only view 16:9 wide screen on the Sony Bravia.Might be able to alter aspect ratio using component video,havn't tried that yet,will post if I can.
Chris.
