Hard drive
Old 28-01-2008, 12:03 AM   #1
1,980, Level: 10
Points: 1,980, Level: 10 Points: 1,980, Level: 10 Points: 1,980, Level: 10
Thanks: Gave 21, Got 4
Hard drive
Hi Im going to get one (WESTERN DIGITAL 250GB PASSPORT EXTERNAL HARD DRIVE works only with usb ) also a TM6900 is it posible to use the hard drive to save my avi movis and files for the PS3 and recording prog. from the TM6900
Can i use it for both ps3 and tm6900 the same hard drive not at the same time but have files form both thanks
Old 13-02-2008, 9:54 PM   #2
mhuk05's Avatar
14,581, Level: 29
Points: 14,581, Level: 29 Points: 14,581, Level: 29 Points: 14,581, Level: 29
Thanks: Gave 31, Got 128
Re: Hard drive
If they record to different folders it should be fine- if the Technomate has a USB port and can be configured to record to an external hard drive.
