Technomate TM6900 622 Software Pal Problem
Old 13-01-2008, 8:11 PM   #1
2,263, Level: 11
Points: 2,263, Level: 11 Points: 2,263, Level: 11 Points: 2,263, Level: 11
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Thanks: Gave 0, Got 2
Hi Folks,
Have tried the 27th Dec v622 official software and have noticed that the Pal output has been seriously degraded on this version.
On increasing contrast the blacks crush as if the clamping has failed!! Also when going to a radio channel audio keeps cutting out for 20 to 30seconds before settling. This was on previous version, where they speeded up radio channel change.
Any one else noticed these problems.
KenH
Old 13-01-2008, 8:52 PM   #2
5,149, Level: 16
Points: 5,149, Level: 16 Points: 5,149, Level: 16 Points: 5,149, Level: 16
Thanks: Gave 16, Got 6
Re: Technomate TM6900 622 Software Pal Problem
if you mean the scart connection, the software hasnt worked for me since 14th october, suggest you ring technomate as the more people complain the better, and ask for a firmware fix
Old 16-01-2008, 7:59 PM   #3
2,263, Level: 11
Activity: 0.6%
Hi.
Scart composite pal output and "S" outputs have always worked for me, but there is no RGB scart output only loop throu, as stated in rear of user manual. The "Colour controls (PAL out only) did not work on early software.
As you suggested I have emailed Technomate.
Ken H
