AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 20-03-2007, 1:50 PM   #1 (permalink)
Thanks: Gave 32, Got 6
Installation of Motorised System
Being a complete idiot when it comes to stuff like this I am looking for a company who would install for me a complete motorised system to pick up all sats.
Anyone any recommendations. I have been on a few websites like the satelite superstore and they only seem to offer the system not installation. BTW I live in Central Scotland
alexander240 is offline
Old 20-03-2007, 4:53 PM   #2 (permalink)
stainway's Avatar
Thanks: Gave 19, Got 128
Re: Installation of Motorised System
Have a look here and play the video clip :
http://www.hisat.com/
LG 42PC1R HD Ready Plasma TV,LG LH-RH760IA HDD Home Cinema set ,Topfield HSCI 7700 HDTV satellite receiver, Xbox 360, Universal remote control Philips SBC RU 760
stainway is offline
aekostas (23-03-2007)
Old 23-03-2007, 1:00 PM   #3 (permalink)
Thanks: Gave 76, Got 48
I live in East Central Scotland and I gave up on the idea; I only found one guy that would do it and he quoted anything from 500 up for installation only.
aekostas is offline
Old 23-03-2007, 3:17 PM   #4 (permalink)
Yeah I have tried all over and no-one seems to do it.
Seems like its going to be a DIY job.
Old 23-03-2007, 4:10 PM   #5 (permalink)
Thanks: Gave 13, Got 304
"How to do it" guide here: http://www.satalogue.com/section11/page3a.htm
Professional installers here: http://www.ukAPSI.com
Yorkshire men are blunt to the point of seeming rude. But inwardly they smile a lot!
SamRadford is offline
aekostas (24-03-2007)
Old 29-03-2007, 1:54 PM   #6 (permalink)
Thanks: Gave 1, Got 3
If you both want installs same day ill come and do for £500 all in.
a.v.sat is offline
Old 29-03-2007, 2:46 PM   #7 (permalink)
Including all the equipment????
Old 29-03-2007, 4:11 PM   #8 (permalink)
LOL
no for both installs
a.v.sat is offline
Old 29-03-2007, 4:25 PM   #9 (permalink)
Thanks For The offer but at £500 just for install I think I can learn what to do and install it myself!!!!!
Old 29-03-2007, 5:18 PM   #10 (permalink)
mitchec1's Avatar
Thanks: Gave 78, Got 83
I'd have a look on digitalspy post your question here, if they don't know an installer they can advise you on kit etc
http://www.digitalspy.co.uk/forums/f...splay.php?f=11
What you know is not a secret
mitchec1 is offline
Old 29-03-2007, 8:03 PM   #11 (permalink)
250 each is what he meant. The price is good and thanks for the offer, but, with no offence intended, I don't know much about you, a.v.sat. Have you got a shop? Do you have insurance and would it apply for this work?
aekostas is offline
Old 30-03-2007, 12:30 PM   #12 (permalink)
mhuk05's Avatar
Thanks: Gave 29, Got 125
There's a "Looking for an installer" section on satellites.co.uk
mhuk05 is offline
Old 31-03-2007, 12:15 PM   #13 (permalink)
Thanks: Gave 3, Got 43
Installing a motorised system is not that hard , I've allways done my own and have fitted a few for some m8's.The tricky part is the tweaking to get all the required satellites in the ark .Firstly ,you need all the required bits ready before you start. What make of reciever are you using ?? ,What mount are you going to use ?? Your installation will have to face South , is there anything in the way ?? like houses are trees ?? . You have to do as much research as you can . I've had my sat hobby since the days of D2-mac and have progressed through the recievers , analogue and now digital . I have allways used the trusty Humax models , but a couple of years ago I bought a Technomate 1500+ . Wow ,what a model , especially for under a ton .It will do for fixed dish's or motorised , it can be patched , it will work with all CAM's , it's easy to set up ,it does a quick blind search , picture and sound quality are excellent .Yes ,there are other recievers on the market ,the Dreambox for instance , this does everything .But ,if you want to spend more time watching the programs than programing the reciver and adding images etc , go for something simple with good support.HTH
Technomate 1500+* Lenson 1m*Geotrack Positioner*Panasonic Th37 Plasma*Panasonic NV-GS11*Sharp VL-WD450 *C500*PIN570*Nokia770*Ubiquio401&501*Navigo sy-895*
rickyt is offline
Old 02-04-2007, 7:01 PM   #14 (permalink)
AMCross's Avatar
Thanks: Gave 39, Got 82
try clearview communications in east kilbride
Tag McLaren DVD32FLR, Tag McLaren AV32R SP 192 BP 7.1EX DAB, Tag McLaren 100x5R,Tag McLaren 100x5R,Aphrodite 192 dacs with 100x3R Stand unique 390m Intel 965OT 2.67ghz core 2 Quad 4gb 677 Kingston ram 6.0tb Maxtors Vista 64bit/mymovies WHS 2.67ghz core 2 quad 4gb ram 5.0tb maxtors
AMCross is offline
Old 04-04-2007, 9:09 AM   #15 (permalink)
installation, motorised, system
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
