12-03-2007, 11:10 PM
#1 (permalink)
Thanks: Gave 10, Got 4
Which HD STBs are there?
Hello. Does anyone have a list (or can name a few) of HD STBs?
Is there any HD STB that puts HD feeds through analog component (1080i)?
Thank you. Best regards
Samsung 43' SP-43Q5HL HD RPTV | Sony STR-DE695 MDS-JE480 CDP-XE570
12-03-2007, 11:29 PM
#2 (permalink)
Thanks: Gave 123, Got 223
Re: Which HD STBs are there?
Pace 810i and Humax HDCI-2000.
I'm pretty sure both do 1080i via component.
All that is necessary for the triumph of evil is that good men do nothing. attributed to Edmund Burke.
Philips 37PF9830, Denon AVR4306, Humax HDCI-2000T, Panasonic NV-HD660B, Philips N1700, Xbox360, Technics SP25, Sony CDP-CX450, Sony CDP-CX455, SkyHD, Nokia N95 8GB
12-03-2007, 11:45 PM
#3 (permalink)
Thank you. So, only DVD players won't upscale on component? I thought it'd be the same with STBs... Can I watch a HD channel going through component to my TV on 1080i then?
14-03-2007, 1:08 AM
#4 (permalink)
Second question first; if your TV's component inputs support 1080i then I think both these boxes will output 1080i over component - the Sky HD box certainly does.
Standard definition DVD players won't usually upscale over any output, there's no point - if you have a 1080 line screen, that will upscale the 576 lines from the DVD player to the 1080 lines of the screen.
High Definition DVD players should output HD signals from HD discs; they may upscale the picture from SD discs but again there's not much point.
14-03-2007, 7:14 AM
#5 (permalink)
Thanks: Gave 15, Got 70
Quite a lot of sd dvd players upscale these days and a few via component,i would have to agree though in theory there seems no point.
Panasonic TH-42PWD8BS plamsa,Oppo 971h dvd,Targa DRH-5100x dvd/hdd pvr,Humax pvr-9200t freeview pvr, Dreambox Dm7000s satellite pvr ,Sony ST-RDB 1080 av amp, Canton cd100, cd50,cd10 speakers
, Svs Sb12+ sub woofer
14-03-2007, 12:24 PM
#6 (permalink)
Thanks: Gave 0, Got 2
You can consider a Homecast HS 5101 CI for less than the cost of a Humax. Just got mine from Germany in less time than ordering from a UK Company! BBC HD worked great out of the box using my current $ky dish. Definitely has Component 1080i.
14-03-2007, 2:53 PM
#7 (permalink)
Thanks: Gave 76, Got 48
There is also the Evesham iPlayer+
EDIT: Err, scrap that, I thought I was on the Freeview forum.
14-03-2007, 5:14 PM
#8 (permalink)
Thank you all.
I thought HD channels would have HDCP and require a digital connection (DVI / HDMI) from the STB to the TV (as upscaling DVDs)... Guess not.
Anymore HD STBs?
