AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 03-03-2007, 11:38 AM   #1 (permalink)
Thanks: Gave 1, Got 5
Combining signals
I've read and read up about combining this and that and am more confused than i was at the start. I will explain my situation. I need to combine 2 sat signals and and a TV signal down one cable and be able to separate at the wall plate into each signal. One sat signal is from a monobloc feeding a sat receiver, the other will be from a minidish with a Sky signal to a Sky digibox. Failing to be able to separate the 2 sat signals at the wall box can I use a feed through from one box to the other and just select which receiver to watch. My main concern is how do I piggy back 2 sat signals and one terrestrial TV signal down the same cable?
Hope the above made sense
bogart99 is offline
Old 03-03-2007, 4:57 PM   #2 (permalink)
Thanks: Gave 13, Got 304
Re: Combining signals
This is the only way:
http://www.satcure.co.uk/accs/stacker.htm
But note that they no longer sell it and ask yourself why.
Yorkshire men are blunt to the point of seeming rude. But inwardly they smile a lot!
SamRadford is offline
Old 03-03-2007, 9:54 PM   #3 (permalink)
Okay im really going to show my ignorance here
Can I not use a combiner to combine both sat signals then use another to combine these signals with the TV aerial one. Then at the wall outlet TV feed to tv and sat signal to sat receiver passed through to the second sat receiver, and which ever sat receiver is switched on thats the one I watch?Ok well was only an idea
bogart99 is offline
Old 03-03-2007, 11:04 PM   #4 (permalink)
Read the page I linked to. You can use a diplexer to combine UHF and LNB signal into input 1. Input 2 takes the second LNB signal. You'll need another diplexer at the output to separate the UHF and LNB feed.
Old 17-03-2007, 10:15 PM   #5 (permalink)
Thanks: Gave 1, Got 1
I potentially had the issue before as i wanted 2 LNB feeds from a distribution box (within the flat) and was advised by the installers (Chapmans in Dudley) that it could be brought together in 1 cable and seperated again. They said it would have cost about £150, but was prone to problems escpecially at set up probably explaining why satcure stopped selling them. I believe commercial/multi home sky instalers can get them still so ring a local sky specialist.
Andy
bashy81 is offline
combining, signals
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
