AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 23-02-2007, 7:07 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Best LNB for BBCHD
Hi guys,
I need your help!
I bought a so called smart 0.1 lnb on e-bay. It lasted only 3 months.
I thought it was a fake, but now that I replaced it with an inverto 0.3 my signal got worse of 15 points!!
With my humax hdci 2000 i had level 64 on BBCHD, now I have level 48!!
As I usually watch BBCHD from italy, I'm concerned of pixellation and loss of signal at any time.
What is the best LNB I can buy in the net?
Thanks in advance.
stauDLP is offline
Old 23-02-2007, 10:56 PM   #2 (permalink)
Thanks: Gave 15, Got 40
Re: Best LNB for BBCHD
I use an Invacom 0.3 in Spain, they seem to be the best all round option.
Inactive is offline
stauDLP (01-03-2007)
Old 01-03-2007, 7:03 PM   #3 (permalink)
Thanks i will consider it!
..and what about smart titanium 0.2?
stauDLP is offline
Old 02-03-2007, 12:38 PM   #4 (permalink)
titaium 0.2 is very good
and my second chioce would be sharp , i use both of them
johnwilliam is offline
Old 03-03-2007, 1:50 AM   #5 (permalink)
Thanks: Gave 8, Got 67
Do you have a separate signal quality indicator? Level itself on many systems can work perfectly anywhere down to 20% or so, the actual figure itself is entire arbitrary.
arfster is offline
bbchd, lnb
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
