17-02-2007, 3:30 PM
#1 (permalink)
Request HD sat box with 40cm dish?
Hi there,
I think i've got 40cm dark grey dish with single cable to a LNB. Now i want to upgrade to HD sat box maybe (Pace - DS810XE) for 2 bedroom - what kind of equipment do i need it?
Do i have to change my dish or just changeb LNB? and couple new sat box?
I'd like to see all Indian + Sky Movies1-10 + Sport 1-3 + HD channels.
Look forward to hear your reply,
Best regards,
FiReDuCk
Home Cinema Entertainment System (Bedroom):
Pioneer PDP-427XD, Pioneer VSX-1016V-S, Lafayette LFDV971D & Bose Acoustimass 6
18-02-2007, 12:03 AM
#2 (permalink)
Thanks: Gave 87, Got 255
Re: Request HD sat box with 40cm dish?
If it's already pointing at 28šE (where $ky transmits from) you just need to substitute a dual , or preferably quad, LNB and run appropriate satellite grade cable(s).
Make sure the LNB you buy will mechanically fit your dish arm though.
Chris Muriel, Manchester
18-02-2007, 8:25 AM
#3 (permalink)
Thanks: Gave 15, Got 70
Best regards,
FiReDuCk
The pace box is for free to air channels (FTA) ,to get the sky channels you need a sky hd box and pay them the subs, i don't know about the indian channels ,some are FTA, BBc hd is FTA.
Panasonic TH-42PWD8BS plamsa,Oppo 971h dvd,Targa DRH-5100x dvd/hdd pvr,Humax pvr-9200t freeview pvr, Dreambox Dm7000s satellite pvr ,Sony ST-RDB 1080 av amp, Canton cd100, cd50,cd10 speakers
, Svs Sb12+ sub woofer
18-02-2007, 5:55 PM
#4 (permalink)
Hi there,
Thanks for reply.
Buying Sat box from sky - they are expensive! but i'd like to buy other brands name which is lots cheaper then Sky's products. Can I buy the card from Sky and plug-in with Pace's sat box? will i be able to receive all channels like i said below?
I've no idea where the dish is point to, can i just plug-in LNB with quad connections from the dish where ever that is pointing to? where can i buy appropriate satellite grade cable(s)? and which LNB would you recommend for mini-dish 40cm?
Will i be able to receive some channels from E.U.?
cheers,
FiReDuCk
