AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 07-02-2007, 7:24 AM   #1 (permalink)
bob1's Avatar
Thanks: Gave 15, Got 70
DiSEqC switch
I'm going to put another satellite dish up and i'm going to connect them with a DiSEqC switch,if i get a 4in 1 out switch (thinking of the future) would it be ok to only have 2 lnb's connected with 2 unconnected inputs or do i need a 2in1.
Thanks.
Panasonic TH-42PWD8BS plamsa,Oppo 971h dvd,Targa DRH-5100x dvd/hdd pvr,Humax pvr-9200t freeview pvr, Dreambox Dm7000s satellite pvr ,Sony ST-RDB 1080 av amp, Canton cd100, cd50,cd10 speakers
, Svs Sb12+ sub woofer
bob1 is offline
Old 07-02-2007, 8:13 AM   #2 (permalink)
Thanks: Gave 3, Got 221
Re: DiSEqC switch
It's fine to have just two of the outlets of a 4-in & 1-out switch. Just make sure to keep the plastic or rubber blanking plugs over the unused sockets to prevent any water damage.
Nigel
nigelbb is offline
Old 07-02-2007, 12:49 PM   #3 (permalink)
Thanks: Gave 0, Got 10
Re: DiSEqC switch
sorry to hijack but do either of you know if you can use a switch like this to connect:
Monoblock lnb + Sky lnb together to create one feed.
I have a monoblock lnb picking up 13+19 but want to have 28 on my box also, i have a seperate dish for that.
Will the swith still work because in theory it will be controlling another switch inside the monoblock lnb??
ginoworm is offline
Old 07-02-2007, 1:45 PM   #4 (permalink)
Thanks: Gave 15, Got 40
Re: DiSEqC switch
Thanks.
As nigelbb has said, yes a 4/1 will be fine, be sure to set them up as ( a ) and ( b) in your receiver menu, or possibly (1) and (2) depending on the make of your receiver.
Waterproofing of the spare connectors is essential.
Inactive is offline
Old 07-02-2007, 1:47 PM   #5 (permalink)
Re: DiSEqC switch
Highly unlikely to work, however I havn't tried it so it may just be possible, but I somehow doubt it.
Inactive is offline
Old 07-02-2007, 5:29 PM   #6 (permalink)
bob1's Avatar
Re: DiSEqC switch
Thanks for the relpies ,i have ordered a 4/1 switch.
ginoworm ,i have seen a manual switch which would be easier than swapping leads over.
bob1 is offline
diseqc, switch
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
