AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 04-02-2007, 10:28 AM   #1 (permalink)
Thanks: Gave 2, Got 3
HD Receiver Topfield TF7700HSCI
I have just spotted this HD receiver on the Satellite Superstore site. It appears to have been available in the rest of Europe for a few months. A review can be found at www.tele-satellite.com
Does anyone have any experience of this receiver?
rover is offline
Old 10-02-2007, 3:36 PM   #2 (permalink)
Nas
Thanks: Gave 4, Got 0
Re: HD Receiver Topfield TF7700HSCI
I'm looking for a receiver that can handle both Sky SD & HD, ie. upscale SD for the foreseeable future and then handle HD when Sky drop their prices. Could this be it?
Also interested in hearing people's experiences...
Nas is offline
Old 11-02-2007, 9:33 AM   #3 (permalink)
bob1's Avatar
Thanks: Gave 15, Got 70
If you want sky this isn't the box for you, you will need to get a sky hd box,you can allways join up later if the price comes down.
Panasonic TH-42PWD8BS plamsa,Oppo 971h dvd,Targa DRH-5100x dvd/hdd pvr,Humax pvr-9200t freeview pvr, Dreambox Dm7000s satellite pvr ,Sony ST-RDB 1080 av amp, Canton cd100, cd50,cd10 speakers
, Svs Sb12+ sub woofer
bob1 is offline
Old 14-03-2007, 5:45 PM   #4 (permalink)
Rogerp01
Posts: n/a
I bought a Topfield TF7700HSCI and I am still unable to receive any of the HD Euro 1080 scrambled channels. The HD Euro 1080 FTA ones are excellent as is BBC HD but it does not like the Irdeto CAM and Euro 1080 card combo at all. I am already on my second Ideto CAM and my second Euro 1080 registered card.
Topfield just don't want to know about it, so it will probably go back for a Humax or Pace.
The Sat's and TP's are wildly out of date even after the latest (Feb 07) firmware update.
It cannot handle 36v so I am still using my excellent Plaza ST500 to steer my dish until my V-box arrives.
The box comes in a choice of ugly '80's retro black or nothing so I have had to hide mine well out of view.
All in all, very disappointing and I think needs to be withdrawn before it ruins Topfields excellent reputation.
I hope this helps.
Old 18-03-2007, 3:33 PM   #5 (permalink)
stainway's Avatar
Thanks: Gave 19, Got 128
Your problem is with the Irdeto CAM and not with Topfield.
Euro 1080 switched to MPEG4 and this cause problems with descrambling using the Euro Irdeto CI CAM from SCM.
You need either old Euro Irdeto module with software 1.06 or new one from SMiT:
http://www.hisat.com/proddetail.php?prod=CAMIRD2
I had Humax HDCI 2000 and Homecast HSCI 5101 and for me the Topfield is so far the best performer-it does auto switch 576i and 1080i over HDMI and component and even the SD channels looks fantastic when you compare to Humax which upscale everything.
LG 42PC1R HD Ready Plasma TV,LG LH-RH760IA HDD Home Cinema set ,Topfield HSCI 7700 HDTV satellite receiver, Xbox 360, Universal remote control Philips SBC RU 760
stainway is offline
Old 31-03-2007, 9:26 AM   #6 (permalink)
Rogerp01
Posts: n/a
Stainway
You are correct,
I knew that the transmissions were changed to MPEG4 this year, I had informed my supplier about it but he insisted that the CAM he sent would work. Of course when he 'eventually' tried it himself it wouldn't so sent me a replacement (three weeks later).
I have another observation with the TF7700HSCI and that is with front-end sensitivity (or lack of).
What gave me concern in the first place was that I lost all my ART sport channels when we had bad weather recently, which is fair enough. However, when I reconnected my Plaza ST500, I had a cracking signal strength and quality. I then changed back to the TF7700 (without moving the dish of course) and did a factory-reset and a new search and could not find any ART channels at all. It was two days later before the signal was strong enough for the TF7700 to resolve it. I cannot find any technical data anywhere to compare the two so I am not sure whether they are all as bad or that mine is faulty.
Roger
Old 31-03-2007, 10:08 AM   #7 (permalink)
stainway's Avatar
Stainway
You are correct,
Roger
Roger,
I know what you mean. Last week I was trying to get some new FTA HD Channel on Hispa and I was surprised that I don't get any channel there. With my previous receiver I had signal etc..
What I did was:
Try using DiseqC 1.2 in place of USUALS-it gives better adjustment.
I also had to adjust my motorized Dish (which is already 5 years old).I had to change the elevation by 1 cm. Now I am getting 99% quality signal on most sat positions.
I use Smart Titanium LNB.
Hope this helps.
P.S.The old Irdeto CAM ver.1.06 works,but you need to restart the receiver sometimes.
The one from SMiT works always.
stainway is offline
receiver, tf7700hsci, topfield
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
