AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 01-02-2007, 8:13 PM   #1 (permalink)
Zaichik's Avatar
Thanks: Gave 38, Got 10
Installing a motorised system - is this reasonable?
I've received a quote from pretty much the only accredited installer in my area that does motorised systems to install a motorised satellite dish and relocate my sky dish to accommodate it. The price is £165+VAT for the labour. There is an additional charge for brackets, mast and bolts. Is this a reasonable price to pay for this work?
While I'm on, I may as well ask this too: I'm planning to get the actual equipment from Satellite Superstore. Are they any good?
Thanks for your help.
Zaichik is offline
Old 02-02-2007, 10:26 AM   #2 (permalink)
Thanks: Gave 1, Got 3
Re: Installing a motorised system - is this reasonable?
I bought a DIY motorised kit off ebay for £120ish and spent a couple of hours installing, with no previous experience. So I should think he could do it in an hour, if that's any help.
tr6rich is offline
Zaichik (02-02-2007)
Old 08-02-2007, 7:40 PM   #3 (permalink)
Thanks: Gave 76, Got 48
Well, the only installer I could find in Edinburgh to fit a motorised dish quoted 500 pounds just for labour. Ihope I am in the catchment of your installer.
aekostas is offline
Zaichik (09-02-2007)
Old 08-02-2007, 7:43 PM   #4 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,104
if your buying the kit yourself then many CAI or other aerial dish installers will do the job the biggest thing i if there is an issue with the system as you will pay to have it taken down packed up sent away and then the replacement fitted seem easier to get the whole lot from same place fitted then any issues they need to sort it
hornydragon is offline
Old 09-02-2007, 1:23 PM   #5 (permalink)
Zaichik's Avatar
Actually, that's a good point. Unfortunately, the local installer is charging so much over the online price for the equipment that I just cannot justify it. I'll just have to hope that it's all OK.... which, with my track record with gadgets, may be forlorn!
Zaichik is offline
Old 09-02-2007, 4:40 PM   #6 (permalink)
Kieron's Avatar
Thanks: Gave 759, Got 506
Tracking the ark is a fiddly job. Lots of swearing from my roof when we attempted it.
Got it in the end though, few hours of fettling required!
"PS3 Friend Name - KieronUK"
All views expressed are my own. Sorry if you don't agree with my viewpoint!
Kieron is offline
Zaichik (12-02-2007)
Old 11-02-2007, 11:04 PM   #7 (permalink)
rhubarbe's Avatar
Thanks: Gave 88, Got 233
You need to make sure your pole/mast is very very plumb, otherwise you'll not be able to track the arc.
rhubarbe is offline
Old 12-02-2007, 12:37 PM   #8 (permalink)
vex
Assured Advertiser
Location: East Anglia or Home Counties, depending on the day!
Thanks: Gave 7, Got 152
As others have said, the trick is getting it to track correctly.
Depending the size of the dish with depend on the tollerences it can work with, typically the smaller the dish the greater the tollerences.
IMO the price you have been quoted is a good one?
Chris
vex is offline
Old 12-02-2007, 3:10 PM   #9 (permalink)
Thanks: Gave 11, Got 6
if you are looking for a motorised reciever go here.you can purchase a 1500 super for less than a £100.it's a brilliant reciever.bearing in mind that a hd version will be on the market soon.give the guys a phone.you'll never look back with this brilliant kit.and it's dead easy to use.
machinehead is offline
Zaichik (13-02-2007)
Old 13-02-2007, 5:01 PM   #10 (permalink)
Zaichik's Avatar
Think you forgot to post a link to the supplier.. Anyway, an order is in with Satellite Superstore for the 1500 CI+ Super (£94) and a 90cm Triax dish with 36V motor and V Box. Should be delivered on Friday, with installation booked for next Friday. Can't wait. Thank you all for your advice.
Zaichik is offline
Old 14-02-2007, 3:32 PM   #11 (permalink)
There is a good forum with all the info you need to install a motorised system, they also sell a Technomate TM-1500ci+ Super full motorised system including cable, wall brackets with bolts\wall plugs, cable, 90cm dish, 0.2LNB F conectors everyting you need in one box for £215 plus £15 delivery. I spoke to the guy who is sound and he said install should cost around £130 give or take a few quid. Also they are a Technomate authorised distributor. Cheers
Chimaera500 is offline
installing, motorised, reasonable, system
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
