29-01-2007, 12:14 PM
#1 (permalink)
Thanks: Gave 60, Got 31
Hotbird and Eurobird via a skydigi box
Have a few questions about trying to get a signal from hotbird/eurobird. Currently I have a skydigibox/dish (which is pointing at 28.2E for the Astra Cluster) and I pick up the freesat channels with that.
I've seen pics of dish's with 3 lnbs each then pointing at different Sat's, i.e. Astra,hotbird and eurobird. If Iwas to add 2 extra lnb's (suppose one of those monoblocks that has 2 lnbs 6' apart) is there an optimum position I should point the dish at or would it be possible to leave it at 28.2E ?
Also the dish is currently at an elevation of 22', does that work aswell for dish's pointing to different satelite's ?
And finally, while testing this , (as I know I'd probably need a better sat receiver later on and a diseqc switch), on the digibox signal test page, what values should you see in "Network ID" and "Transport Stream" when connected to hotbird or Eurobird ?
thanks,
d...
29-01-2007, 7:00 PM
#2 (permalink)
Thanks: Gave 13, Got 304
Re: Hotbird and Eurobird via a skydigi box
See http://www.satcure.co.uk/tech/page9.htm
Astra 2 at 28.2'E
Default transponder - 11.778V
Network ID is 0002
Transport Stream is 07d4
Hotbird
Network id = 013e
Transport stream = 1450
Astra 1 at 19.2'E
Network id = 0001
Transport Stream = 042c
See http://www.satcure.co.uk/tech/astra19.htm
(But I think it's well out of date).
Yorkshire men are blunt to the point of seeming rude. But inwardly they smile a lot!
29-01-2007, 8:57 PM
#3 (permalink)
thanks  thats enough to get me started...
31-01-2007, 7:23 PM
#4 (permalink)
Thanks: Gave 0, Got 299
You will NOT be able to use a monobloc (at least if it has inbuilt DiSEqC) as the Sky dodgibox will not be able to send the required signals to change satellites via the DiSEqC.
You will need a "proper" satellite receiver to do that.
You would be able to use a dodgibox to view more than one satellite by changing cables each time you want to change satellite BUT any channels on satellites other than 28.2 (The one Sky digital broadcasts from) will need adding manually as "other channels" on the Sky box and you are limited to a maximum of 50 channels.
Sky+ Pace PVR1,Sky+ Amstrad PVR3Sky Pace 2500, Fortec Star Ultra Diamond, Technomate TM9100, Fortec Star 5100 CI Diamond + Dragon CAM, Pace Twin view, Nokkia 9850 On Digital Box, Force DMaster 1122s, 2.8 ghz P4, Skystar2 PCI card, Artec USB Freeview box
01-02-2007, 12:39 AM
#5 (permalink)
Thanks: Gave 15, Got 40
Agreed, A Sky Box isn't really suitable for anything much other than Sky.
01-02-2007, 11:10 AM
#6 (permalink)
thanks for the replies guys  , I basically have a 2nd dish coming so I want to try it out first with the skybox to see if it is possible to get signals from the other sat's and then I'll go and get a proper recevier
01-02-2007, 12:25 PM
#7 (permalink)
Thanks: Gave 36, Got 19
If you mean by this that you're putting another dish up - I *think* you need planning permission. Though I'm not 100% sure if that holds in Ireland too.
You can have a single dish with a triple LNB holder - they come in one unit ready for pointing to all of Hotbird (13E), Astra (19E) and Sky (28E). Take the feed from the Sky LNB to your existing digibox, then take the feed from the other 2 LNBs to a new receiver, like a Technomate.
01-02-2007, 4:04 PM
#8 (permalink)
thanks, never heard of a planning permission thing for 2 dish's in Ireland, might look into that to be sure.
Suppose could put a monoblock and a single lnb on one dish ( if from what I read is true a bigger 80cm dish), to do it that way though, which lnb should be the center one ? the one pointing to 19' ?
01-02-2007, 4:10 PM
#9 (permalink)
Thanks: Gave 56, Got 19
I've got two dishes on my house, one has a mono-bloc and the other is sky with a quad.
Sky receivers are only good for sky, believe me you can't do anything GOOD with them.
