AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 26-01-2007, 4:48 PM   #1 (permalink)
Is FreeSat this bad?
I've been told by a couple of people that if I get a Freesat Sky dish I will have loads of problems with interference (ie - during strong winds etc)
Does this sound right? I was thinking of buying Freesat but now Im having my doubts. If I go for freeview then it means that I have to pay for a new aerial to be fitted.
What are the pro's and con's to freesat?
Anybody on here wanna share their views and help me decide what to do?
jezbenbow is offline
Old 26-01-2007, 4:55 PM   #2 (permalink)
Starburst's Avatar
Thanks: Gave 87, Got 632
Re: Is FreeSat this bad?
Strong winds will have no affect on the signal however if a dish is poorly installed than obviously it could move and even fall off which would ruin reception. Remember that an aerial could also be blown down and that would for a time ruin terrestrial reception, end of the day weather and enviroment could disrupte any distribution system even cable.
Both Freeview and Freesat are fine if installed correctly so choose which you want from the channel lineups, if you choose Freeview than also consider a DVR they make watching telly so much more user friendly
"The Nac Mac Feegle are, well, they’re like tiny little Scottish Smurfs who have seen Braveheart altogether too many times."
Starburst is offline
Old 26-01-2007, 5:40 PM   #3 (permalink)
bob1's Avatar
Thanks: Gave 15, Got 70
I have only ever lost the signal in very heavy rain or snow,2 or 3 times in a year.
Panasonic TH-42PWD8BS plamsa,Oppo 971h dvd,Targa DRH-5100x dvd/hdd pvr,Humax pvr-9200t freeview pvr, Dreambox Dm7000s satellite pvr ,Sony ST-RDB 1080 av amp, Canton cd100, cd50,cd10 speakers
, Svs Sb12+ sub woofer
bob1 is offline
Old 26-01-2007, 9:35 PM   #4 (permalink)
Thanks: Gave 13, Got 304
I have an 80cm dish and have not lost the signal in ten years.
Yorkshire men are blunt to the point of seeming rude. But inwardly they smile a lot!
SamRadford is offline
Old 27-01-2007, 7:04 PM   #5 (permalink)
wod
Thanks: Gave 0, Got 2
you wont have any problems with sky minidhishes as they are mesh so the wind will blow through them and they are small so aren't affect as much as motorised satellite dishes
wod is offline
Old 28-01-2007, 12:38 PM   #6 (permalink)
You are mistaken. Sky minidishes are not "mesh". Some types have perforated holes but these do not reduce the wind loading at all.
Old 28-01-2007, 6:14 PM   #7 (permalink)
Chris Muriel's Avatar
Thanks: Gave 87, Got 255
Indeed. The holes are tiny and are too small a fraction of the overall area to make any significant difference to wind loading.
Chris Muriel, Manchester
Chris Muriel is offline
bad, freesat
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
