21-01-2007, 4:09 PM
#1 (permalink)
Thanks: Gave 3, Got 0
Satellite Dish To Recieve ASTRA, HOT BIRD & EUROBIRD...?
I am looking into recieving free-to-air satellite television. I have done a fair bit of research and my current location can recieve the following satellites:
ASTRA 1C
ASTRA 1D
ASTRA 1E
ASTRA 1F
ASTRA 1G
ASTRA 1H
ASTRA 1KR
ASTRA 2A
ASTRA 2B
ASTRA 2C
ASTRA 2D
EUTELSAT HOT BIRD 2
EUTELSAT HOT BIRD 6
EUTELSAT HOT BIRD 7A
EUTELSAT HOT BIRD 8
EUROBIRD 1
I believe an 80CM satellite dish should be suitable to recieve all of these satellites with a good signal. I plan to connect the satellite dish to a computer with a satellite PCI card in it. Could you give me a little more information into exactly what dish or any other accesories I would require? I believe to recieve all of these satellites I would need a dish with dual LNB's or even tri LNB's, could you confirm this?
Many thanks.
21-01-2007, 9:28 PM
#2 (permalink)
Thanks: Gave 0, Got 2
Re: Satellite Dish To Recieve ASTRA, HOT BIRD & EUROBIRD...?
you would need a dish with 3 lnbs 13,19, 28east and a diseqc switch
22-01-2007, 12:19 AM
#3 (permalink)
Thanks: Gave 15, Got 40
Plus a multi LNB holder and a Sat Meter and cable/clips and F Connectors.
22-01-2007, 10:57 AM
#4 (permalink)
Thanks: Gave 13, Got 304
There's a good explanation with photos here:
http://www.satcure.co.uk/tech/page9.htm
Yorkshire men are blunt to the point of seeming rude. But inwardly they smile a lot!
22-01-2007, 2:43 PM
#5 (permalink)
Thanks: Gave 29, Got 125
Or get a Moteck SG2100a motor for very little $$$.
22-01-2007, 6:04 PM
#6 (permalink)
Has anyone used a TechniSat Multytenne before? I have read reviews and it gets nothing besides praise. I read that the dish picks up good quality signals, but has only been tested as far North as Birmingham, I wondered if a significant difference would be known about in Sheffield.
23-01-2007, 12:41 PM
#7 (permalink)
Thanks: Gave 0, Got 4
Morning all,
This is my first post so be gentle! Im looking to setup a fairly basic system to get BBC HD and a few others..potentially the footie *ahem*
I dont really want to go the way of a motorised dish, but dont want to be restricted to 1 Sat. I have seen a Quad LNB 60 cm dish (ebay 220071502735)
Can someone explain to me about multi LNB's please.. is it one physical LNB right, that can pick up up to 4 Sats? What range does it have ie how far apart can the 4 be? how configurable is it, and what are the alternatives?
EDIT
Im now thinking that to receive more than one sat on a fixed dish, you will need more than one physical LNB...but can someone confirm what is meant by 'QUAD LNB' in regard to the Dish in the link?
Finally is there a setup guide on here for a fixed dish? There are plenty for motorised but non for fixed multi LNB's.
thanks again..great site!
23-01-2007, 1:18 PM
#8 (permalink)
It probably means it can be connected to 4 receivers.
A small dish with 4 LNBs - think about the way a dish works. It points at one satellite (or group of sats close together) and "bounces" the signal onto the LNB. A small dish can't really point at 4 different satellites at the same time and have good signal strength on all of them e.g. from 28.2E to 13E. People do it (and I'm sure someone will post here about how easy/ great it is) but it's much easier with a motor and a 90cm dish.
23-01-2007, 3:49 PM
#9 (permalink)
All I want to do really pickup Astra 2 (Freesat, BBC HD etc I think) and Eutelsat W2 (football), 28e and 16e respectively, but not sure whether a motorised dish or having 2 LNB's on one dish is the cheapest and easiest way to go!
Also anyone know what size dish is required to get Eutelsat W2?
23-01-2007, 4:29 PM
#10 (permalink)
Looks like an 80cm or 90cm with 2 LNBs and a diseqc switch will get it:
http://www.lyngsat-maps.com/maps/ew2_wide.html
Or try a 3 way LNB to get 16E, 19.2E and 28.2E
24-01-2007, 2:41 PM
#11 (permalink)
Can you explain why you think a 80-90 cm is required?
According to those satellite maps, both Eutelsat W2 and Astra 2, fall well within the 65-85 cm range...Is it something to do with receiving 2 signals that requires the dish to be bigger?
I was kind of hoping to get away with a 60cm dish...maybe im being overly optimistic!
Also are there any non asthetic differences between a meshed dish and a solid one?
24-01-2007, 3:22 PM
#12 (permalink)
Probably because 2 of the LNB's are not focused at the full dish face, thus losing some signal.
24-01-2007, 7:55 PM
#13 (permalink)
60cm might be OK with 1 LNB but with 2? Which will be the prime focus and which is likely to have poor reception? But it's up to you
25-01-2007, 12:16 AM
#14 (permalink)
for 16east a 80cm dish at least to get the best signal
depends on where you are in the uk
25-01-2007, 9:25 AM
#15 (permalink)
The midlands
