can i extend a satellite cable?
Old 01-09-2006, 1:39 PM   #1
Thanks: Gave 7, Got 26
Hi all, im moving my av gear about 2 metres across from where the cables come into the house and hoping to extend the cable. Would it be possible for me to fit a wall socket that the sat cable would go into , then antoher one 2 metres away that it would come back out of?
Old 01-09-2006, 2:17 PM   #2
Thanks: Gave 13, Got 15
Re: can i extend a satellite cable?
I did the same a couple of weeks back. I bought a couple of these from Maplin. Only seem to come in white. Everything seems fine using these cables.
Mine are currently just laid alongside the skirting board, on the floor, but I'll be using conduit to hide the cable, as only about 1 to 2m will be on show.
Old 01-09-2006, 3:08 PM   #3
They would be perfect. Do you know if you can get a wall box, sos i can hide that cable in teh wall with each end just coming out of a box?
Missus needs no cables!
Old 01-09-2006, 3:12 PM   #4
Thanks: Gave 2, Got 110
If Sky know you were doing that you would lose any warranty on the box you have remaining. We DO NOT use faceplates (I'm sick of saying that now!).
Face plates weaken your signal. The best way to extend the cable is to use an 'f' barrel that joins 2 cables together by f connectors. This is however not approved by Sky who would want you to replace the whole cable back to the dish. To put multi points in your room you need to use a quad LNB with 2 seperate wires going to each corner.
Cheers, Franc
Old 01-09-2006, 3:49 PM   #5
Cheers, Franc
Does it really weaken the signal? How about if i just buy one of these connectors, then hide the cable in the wall and have it coming out oof a blank faceplate with a hole in the middle?
Old 01-09-2006, 4:07 PM   #6
Limited Member
Thanks: Gave 5, Got 250
Any discontinuity in a cable weakens the signal. Really you want a single cable from your dish to your satellite box.
Once you start adding connectors/faceplates etc. you risk starting to get breakup especially during bad weather.
Beancounter (28-08-2011)
Old 01-09-2006, 5:11 PM   #7
bob1's Avatar
Thanks: Gave 34, Got 147
I soldered two cables together ,although i don't recomend it.
Old 01-09-2006, 5:14 PM   #8
Now that IS okay and something I do reconmend to my customers.
Okay you have a hole in the wall and our grommit (if fitted) still doesn't hide the mess, then a face plate with the pcb removed so that the cable just pokes through the hole in the middle is of course fine as there is no join in the cable.
Cheers, Franc
Old 01-09-2006, 5:21 PM   #9
Eminent Member
hornydragon's Avatar
Location: Somewhere near the M4 most of the time, sometime the M5 or 6 or 25
Thanks: Gave 103, Got 1,421
100-00107 "F" connector wall plate for Digital satellite and TV
http://www.satcure.co.uk/accs/page15.htm#plates
This an F joiner in a white plate and just like using an F joiner as an aside frank, i have seen these can you send sat signals over cat5? or DTT aerial over cat5? http://www.vtx.co.uk/video/sourcerer.htm#850 wonder how good it would be?
Old 01-09-2006, 5:28 PM   #10
if you must still use one then this is the only one I would use to give you the least problems
Cheers, Franc
Old 01-09-2006, 8:20 PM   #11
Thanks: Gave 13, Got 372
The fully screened plates are generally OK. I have two diplex combiners in the loft that combine SAT, TV and FM. This feeds a single cable connected to a C13897 triplex decombiner plate downstairs. There's no effect on the Digibox signal strength or signal quality indications, and no channels suffer "break up". (The cable is RG6 with aluminium foil). In theory, all of these "defects" could lead to problems. In practice they don't.
Old 01-09-2006, 9:29 PM   #12
Give it time and we'll see who has problems first! RG6 tends to play up after a few years. Cheers, Franc
Old 02-09-2006, 12:48 AM   #13
OK, I'll wait. It's only been there ten years. I should add that I slapped a coat of paint on it when it was first installed. That should help keep the moisture out.
Old 02-09-2006, 7:24 AM   #14
bob1's Avatar
I think the problem is it as aluminium foil screen which corrodes over time,i can beat yours i have some transmission line which as an aluminium foil screen, thats been there 20years now, i would wait much longer ,the cable from my tv aerial is at least 25 years old but could be much older .
Old 02-09-2006, 9:24 AM   #15
Darn. In that case I may be dead before I experience any problems with reception.
Old 02-09-2006, 11:50 AM   #16
Thanks: Gave 22, Got 1,053
My analogue system ( a twin and a dual lnb feeding two mini-magics for a multiroom system) using rg6 (ali foil) cable has now been in place for 24 years with no problems so far - silicon grease and self amalgamating tape used on all exterior connections..
Old 02-09-2006, 7:13 PM   #17
That would be "silicone". (You can make chips out of silicon but not grease!)
Old 02-09-2006, 11:57 PM   #18
i stand corrected it should be "silicone grease" - but note you can make silicone grease from silicon
From wikipedia
Silicon is the principal component of most semiconductor devices and, in the form of silica and silicates, in glass, cement, and ceramics. It is also a component of silicones
Old 04-09-2006, 8:33 AM   #19
And how many boxes have you all gotten through so far?
To convince you all here is a good web page to tell you the diffrence between the cables.
http://www.aerialsandtv.com/cableandleads.html
Cheers, Franc
Old 04-09-2006, 6:18 PM   #20
bob1's Avatar
Rg6 might not be the best cable but H109 / CT100 Type isn't the best either why not go for some WF-165 if you want something better.
Old 11-09-2006, 3:58 PM   #21
Cheers, Franc
None have gone t*ts up.
20+ Year old Amstrad SRD600 (A Rolls Royce in its day - one of Amstrads best ever products)
Pace MSS1000 approx 12 years old
24 + Year old Discus Ellipse
All wiring and LNBs will be replaced anyway soon - Incompatibilities between my Distribution boxes and my Digital non Sky boxes,
Old 11-09-2006, 8:27 PM   #22
not strictly a sat cable, but can i put a standard ariel coax in a wall along with my other cables. There is no issue there is there?
Old 12-09-2006, 1:00 PM   #23
Ariel is a brand of washing powder. So called "low-loss" Aerial cable is usually crap with (at best) 60% shielding. Put it close to mains cable (and other sources of interference) and you could be in for a nasty surprise.
Old 12-09-2006, 1:16 PM   #24
So i cant put it in the trunking with all of my scart, component etc cables?
Old 12-09-2006, 4:00 PM   #25
You best use H109f (the best sat cable) or equivelent cable to minimise interference from the power cables.
Cheers, Franc
Old 12-09-2006, 4:37 PM   #26
the power cables are no where near.
Basicly, its for my standard house aerial. Goingto just extend it a few metres u the wall so that i can get my freeview via my tv.
Old 16-09-2006, 3:18 PM   #27
Thanks: Gave 290, Got 209
Sky engineer installed HD for me a few days ago and I noticed he used two connectors on the cable from the dish as he cut the cable to short to reach the HD box.
Should I be asking for a new "one piece" cable?
Old 16-09-2006, 5:19 PM   #28
For piece of mind then yes as it will be covered in your warranty period.
Cheers, Franc
Accylad (16-09-2006)
Old 19-09-2006, 11:08 AM   #29
I don't understand your abbreviations "u" and "i".
For Freeview it's best to use fully-screened coaxial cable in a continuous run. Joining cables can give unpredictable results.
