All the satellites are orbiting above the equator at a fixed height, so from where you are standing they will appear as an arc across the sky (not a perfect arc, but that's another story). The satellites are referred to as degrees east or west of true south (not magnetic south !). The satellite elevation can be calculated, but you need to know what your latitude is, because a satellite will appear lower in the sky in scotland than it does in portsmouth. If you've already found one satellite, then it's easier to find the rest. To go from 19.2 E to 28.2 E, you need to swing the dish 9 degrees further east, and the elevation will be a little lower. Getting a motorised dish to track across the Sky is a delicate art, and can take hours to get right.
To recap - the satellite you need is at 28.2 degrees East of true South. This time of year the best way to find true south is to put a garden cane in the ground at exactly noon GMT
(1 PM BST !) and the shadow of the Sun will point exactly north.
Dish Azimuth calculator
