RF to Composite Converter
Old 03-04-2006, 10:07 PM   #1
Hammingus
Posts: n/a
I have gave up on my SKY digisender due to interference from Microwaves and Wireless Network. No matter what channels I use there is always something that doesn't work quite right!
SO, I have a coax run already under the floorboards to my 2nd room that I want to make use of. I connect this to RF out on my SKY digibox which gives me an RF signal in 2nd room.
But my problem is that I do not have an RF IN device in 2nd room. I have a composite running from AV Amp to Projector. So basically I need something to convert RF to Composite and phono. And I'm really not sure how to do that!
Can anyone help me out before I go and buy more bits that the shop won't take back?
Old 03-04-2006, 10:28 PM   #2
JayCee's Avatar
30,375, Level: 42
Points: 30,375, Level: 42 Points: 30,375, Level: 42 Points: 30,375, Level: 42
Activity: 36.5%
Activity: 36.5% Activity: 36.5% Activity: 36.5%
Thanks: Gave 168, Got 1,186
Any old VCR with RF in and scart or phono/bnc for video and audio out will do.
It doesn't even have to be working mechanically.
Old 03-04-2006, 10:28 PM   #3
av2diefor
Posts: n/a
No such thing really.
You would have to buy a cheap tuner ( loads of options and from £25)to convert the rf back to a picture.
You could fit an rca plug onto the cable, then a composite to s-video convertor and plug it into the sky box, wont change channels though or no audio.
Old 03-04-2006, 11:19 PM   #4
Hammingus
Posts: n/a
Thanks guys,
I did think of using a VCR JayCee but ideally I do not want to have to put one in the 2nd room as I am out of space on my rack! Do I have any alternatives?
av2diefor, not exactly sure on the setup or type of tuner you are suggesting but the fact that I may not have audio doesn't sound too good.
Cheers,
Alan
Old 03-04-2006, 11:53 PM   #5
av2diefor
Posts: n/a
Any sort of analogue tuner mate, you need it to decode the signal from rf2 out, it will also give you audio.
As has been mentioned a vcr is your best bet.
If you can run another cable for auido you could use it the way i described above also.
Old 04-04-2006, 7:38 AM   #6
29,695, Level: 42
Points: 29,695, Level: 42 Points: 29,695, Level: 42 Points: 29,695, Level: 42
Thanks: Gave 69, Got 316
The Zinwell PV200 from Keene Electronics will do what you want, and a lot more. It will receive UK RF signals and output them in composite, s-vid, VGA and audio. It will also convert from composite/s-vid to VGA. Price is £84.99
Old 04-04-2006, 8:09 AM   #7
Senior Moderator
LV426's Avatar
42,412, Level: 50
Points: 42,412, Level: 50 Points: 42,412, Level: 50 Points: 42,412, Level: 50
Activity: 31.8%
Activity: 31.8% Activity: 31.8% Activity: 31.8%
Thanks: Gave 1,530, Got 1,592
As already suggested, an old VCR would be cheaper. You could even hide it and leave it "on".
Old 04-04-2006, 8:11 AM   #8
29,695, Level: 42
Just giving all the options. The Zinwell at 9" x 6" x 1.5" is slightly smaller than your average VHS, and consumes rather less power, too
Old 04-04-2006, 12:41 PM   #9
12,548, Level: 26
Points: 12,548, Level: 26 Points: 12,548, Level: 26 Points: 12,548, Level: 26
Thanks: Gave 13, Got 372
However you do it, you'll get mono audio and mediocre picture quality.
