Ske Remote and Samsung SP50L7HXX/XEP
Old 03-04-2006, 12:40 PM   #1
Keithdoull
Posts: n/a
Hello all,
Im a first time poster, and was hoping that someone could point me in the right direction as to the sky remote control code that is compatable with my Samsung SP50L7HXX/XEU rear projection tv set. i only want to be able to adjust the volume of the tv so i dont need have to have the tv remote at my side along with the sky.
ive tried the codes and followed the istructions from other sites but to no avail. Im not a tech newbie but i am very unsure when it comes to tv set ups, so please excuse any questions that i ask which seem to be obvious (to all you) to answer.
Old 03-04-2006, 11:17 PM   #2
peter_pan
Posts: n/a
It should be able too. The code should be 0060
Turn your TV on then press TV on the sky remote hold select and the red button down until the red light blinks twice. Then press tv again and put in 0060 then press standby if it terns off press select. If it doesn’t press tv then standby repeat this (tv then standby) until it turns off, then press select. If that doesn’t work try ringing sky for help.
