Originally Posted by Rosie
............. Anyway---I did explain (on the DVD Forum)that I had more or less eliminated the cables being at fault as I rplaced it with a monster RF cable off our other main room Tv( a Plasma which I know are OK) and the result was the same ---so surely that proved a point...the point of connecting the cables was to check if there was a fault in the cables..yes??? Well if I tried with Ok cables and the result was the same surely thats the answer you were asking.
No, it sounds to me like they were trying to eliminate the DVD recorder from the equation by by-passing it (I wasn't aware of the original thread). Presumably the idea was to ascertain if the RF from the DVD recorder was interfering with the RF from the Sky box. Choosing the RF channels for Sky boxes and DVD recorders isn't easy - people think that all they need to do is to pick an unused channel, but unfortunately it's not as easy as that.
To change the RF channel on the Sky box, you need to press the following buttons on the remote in fairly quick succession......
Services, 4, 0, 1, Select
This takes you into the engineers menu. One of the options in there is to change the RF output channel.
Don't change any of the other settings.
