AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 01-03-2006, 2:49 PM   #1 (permalink)
Thanks: Gave 1, Got 4
Failed Recording Technical Fault-3?
My recording of CSI failed last night. Does anybody know what Technical Fault 3 is please?
Senrap is offline
Old 01-03-2006, 5:06 PM   #2 (permalink)
carussell's Avatar
Angry Channel Renumbering?
Mine too along with Prison Break later in the evening. It seemed to have something to do with the channel renumbering as when I set up a new timed recording it worked fine.
I then spent about an hour deleting all my series linked recordings and setting them back up again - not willing to take any chances as the other half would kill me if any of hers failed
Hope this is of some help.
Regards
Colin R
carussell is offline
Old 01-03-2006, 5:42 PM   #3 (permalink)
Brilliant Colin R. That makes sense and now you say it I remember I had to reset the recordings when a previous renumbering took place.
However, I'm not quite sure why it affected a recording on Channel 5 though because the number has not changed.
In think the problem may be one peculiar to channel 5 and possibly other channels whose numbers have changed because my recordings on FX were fine.
Thanks for your help.
Michael
Senrap is offline
failed, fault3, recording, technical
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
