AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 27-02-2006, 8:29 PM   #1 (permalink)
Unhappy please HELP!!! please read!
please help peeps.i bought a amstrad sky+ drx 180 from one of them stalls in town. and when i plugged it in nothing happend.but the fuse is ok.and i have a seagate hardrive. my sky+ doesnt even turn on or the light dont even come on not even a flash. what do i have to do? is there something i have to press or hold or type a code to format it or format the hardrive through the pc? plz help.thnx really appreciate it
azz4eva is offline
Old 27-02-2006, 8:40 PM   #2 (permalink)
JayCee's Avatar
Thanks: Gave 73, Got 741
Take it back...it's obviously faulty.
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
JayCee is offline
Old 27-02-2006, 8:41 PM   #3 (permalink)
FMC
Thanks: Gave 1, Got 2
I think your screwed unless you can find the guy that sold you it.Either that or take it to bits and see if your getting a voltage out of the power supply and try and fix it.
FMC is offline
Old 01-03-2006, 1:06 AM   #4 (permalink)
Red face how
how do i do that? just formatted the hd through my pc (ntfs) . should i have done that? and is there a way to conect the sky without the hd because the only way i can see is that it conects from the power supply to the hd then to the motherboard using a slave cable. i think it mite be the slave cables.what do you think? plz help.want my sky+ to work because never had one before
azz4eva is offline
Old 01-03-2006, 7:54 AM   #5 (permalink)
Thanks: Gave 69, Got 314
The box should format its own drive, and the box power lights should come on, even if the drive is not formatted. No lights = serious problem with the box - take it back for a refund.
Nick_UK is offline
Old 01-03-2006, 11:08 PM   #6 (permalink)
Question hmmm.strange
its quite strange because when i opened it and took the fuse out nothing happened when i plugged it in but when the fuse was in it gave a little shock everytime i plugged it in.is it the fuse? or do you think its the cables that connect from the power supply to the hd to the motherboard?
azz4eva is offline
Old 01-03-2006, 11:20 PM   #7 (permalink)
JayCee's Avatar
I suggest you screw this together pronto before you seriously injure or kill yourself... there are high voltages present in this digibox and you obviously haven't a clue what you're doing.
Other than replacing/upgrading the HDD there is nothing an amateur can "repair" in these digiboxes.
JayCee
JayCee is offline
Old 01-03-2006, 11:21 PM   #8 (permalink)
Abbeygoo's Avatar
Thanks: Gave 717, Got 714
Put it down to experience and move on ...... those aren't the droids you're looking for.
Steve PSN : abbeygoo
Official AVF League Premiership Peterborough United
Official AVF World Cup MEXICO
"Fear can hold you prisoner, hope can set you free"
Abbeygoo is offline
Old 01-03-2006, 11:38 PM   #9 (permalink)
Carl Stock's Avatar
Thanks: Gave 554, Got 123
azz4eva,
You had better put this box back together without touching its insides. It is possible to get an electric shock, possibly fatal, even when everything is unplugged. This is because many components inside can still hold an electrical charge for hours after being turned off.
As these types of boxes are actually computers, there is nothing that can be repaired. If the hard disk is faulty, then that could be replaced. However, it sounds like the box itself is faulty.
If you can, take it back – you do have some rights.
Regards,
Carl
Carl Stock is offline
Old 01-03-2006, 11:41 PM   #10 (permalink)
Lightbulb
yea i think your right.im going to give it back.but im keeping the hd for selling me faulty goods.lol. does anyone know where i can get a really cheap sky+ from? doesnt matter if its got no hd.because i got one.thnx u guys.
azz4eva is offline
Old 01-03-2006, 11:48 PM   #11 (permalink)
Carl Stock's Avatar
You could get a Sky+ box from Sky!
That is, unless, you cannot for some reason.
Regards,
Carl
Old 01-03-2006, 11:50 PM   #12 (permalink)
JayCee's Avatar
Originally Posted by Carl Stock
JayCee,
I think you meant this to refer to "azz4eva"
JayCee
JayCee is offline
Old 01-03-2006, 11:53 PM   #13 (permalink)
Carl Stock's Avatar
Whoops! My apologies! Doing too much at once!
Hang on while I go and hide in that corner over there...
I have my excuses... honest!
Carl
PS I have corrected it now!
Old 02-03-2006, 12:37 AM   #14 (permalink)
Smile
i have had problems with sky over the past and dont want to go there again.i want to buy one off someone who pobably might sell it because there hd dont work or they dont need it anymore.or there are minor bugs etc.so if anyone is selling, then im willing to buy. my email is am4eva@gmail.com by the way.thnx peeps you guys are great
azz4eva is offline
Old 02-03-2006, 8:17 AM   #15 (permalink)
I suppose you're aware that the recording features of Sky+ will only work if you talk to Sky (and pay them £10 a month) ?
Nick_UK is offline
read
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
