AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 25-02-2006, 10:30 PM   #1 (permalink)
Thanks: Gave 3, Got 0
Rgb Transmitters/receivers
Does anybody know of a transmitter/receiver which transmits RGB rather than PAL.
I would like to be able to watch sky tv in my bedroom by using the wireless transmitter/receiver.
The catch i can see is the signal is only composite (PAL) rather than RGB signal.
I am saying this in advance of me receiving my new 26" samsung lcd and hoping the lcd picture will be ok on rgb !
Thanks Very much in advance.
Great web site for information !
Phil D
phil_744 is offline
Old 25-02-2006, 10:36 PM   #2 (permalink)
SeanT's Avatar
Thanks: Gave 62, Got 217
buy another three cheap pairs and the relevant RGBs converters, you should be able to send it then, there is no real dedicated solution I have seen (as any wireless transmission of video is pretty bodged unless you have a huge budget)
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (CM260, IMON, Tosh HDDVD-ROM, E2200@2.75GHz, 2400XT, 2GB, 320GB, Sweetspot SDI card,Happauge HVR4000, MCE'05), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
SeanT is offline
phil_744 (26-02-2006)
Old 26-02-2006, 2:08 AM   #3 (permalink)
Sorry for being thick -
Are the rgb converters you mentioned just the scart rgb adaptor ?
Thanks,
phil_744 is offline
Old 26-02-2006, 12:00 PM   #4 (permalink)
Thanks: Gave 69, Got 314
If you are that concerned about picture quality, a TV sender is probably not the answer, because they are prone to interference, because they share the same frequency band as Wi-Fi and Bluetooth. All you need is for your next door neighbour (or even yourself) to have a wi-fi network in the house, and the risk of interference is high.
Nick_UK is offline
Old 26-02-2006, 5:59 PM   #5 (permalink)
MAW
MAW's Avatar
Thanks: Gave 26, Got 494
A better solution is to use s-video over cat5 if it's sky+. It costs a bit more than a composite sender, far better quality, and just 1 thin beige wire to run/hide. Up the outside of the wall perhaps?
MAW is offline
Old 26-02-2006, 10:43 PM   #6 (permalink)
MAW - Thanks for the reply.
On the s-video cable, do you know what max length i could use before the picture quailty starts getting poor !
I was reading on some other forums you could maybe only go upto about 5metres ?
Thanks,
phil_744 is offline
Old 26-02-2006, 10:50 PM   #7 (permalink)
MAW
MAW's Avatar
5-7m with just s-video yes. Using cat 5 and baluns, 200m is perfectly OK. I take it your house is not that big?
MAW is offline
rgb, transmitters or receivers
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
