AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 24-02-2006, 7:35 PM   #1 (permalink)
Signal boosters in conjunction with indoor amplified aerials
Have freeview TV finally got set up with amplified indoor aerial, temp renting property so dont really want to change non digital outdoor aerial setup.
Seem to have reasonable strength signal but can this be boosted with a signal booster or do they only work with non amplified signal, if that makes sense.
Any advice appreciated
richardworrall is offline
Old 24-02-2006, 8:11 PM   #2 (permalink)
Thanks: Gave 0, Got 45
I've read in other forums where two amplifers have been used in series on weak signals, so I can't see a problem.
FrankS is offline
Old 25-02-2006, 8:35 AM   #3 (permalink)
clockworks's Avatar
Thanks: Gave 32, Got 170
You don't need to worry about signal strength too much, it's signal quality that's important. Both my STBs show strength around 60%, but quality is 100%.
If the quality is showing as 100%, adding a booster to increase strength won't improve the picture.
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 1000, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac
clockworks is offline
Old 25-02-2006, 9:58 AM   #4 (permalink)
I have two ariels, one on the roof feeding the main TV and twin tuner PVR, no amplifier and it works great. The a wideband ariel in the loft with a 4 way TV ariel amplifier. Without the amplifier we couldn't get freeview with it we can, signal strength is about 45-55% but quality is 80% plus and I have 3 freeview units running off it with no problems.
FrankS is offline
aerials, amplified, boosters, conjunction, indoor, signal
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
