AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 23-02-2006, 10:30 PM   #1 (permalink)
Thanks: Gave 5, Got 1
Signal Boosters
Hi,I have weak signals on a couple of channels in freeview and I wondered if a signal booster would sort it out for me,I was looking at them in Maplins today at £24.99 and thought it might be an answer.What do you think ?
Don
Panasonic PWD7 37",Panasonic DMR-ES20DEB,Ixos 601 scart.Virgin Media V +box
don-tucker is offline
Old 23-02-2006, 11:30 PM   #2 (permalink)
Thanks: Gave 3, Got 2
hi i got this one at argos and you can run two tvs from it. you can try it and take it back if there is no improvement my signal went from 50/60 to amost 100
http://www.argos.co.uk/static/Produc...2Bboosters.htm
ninegt is offline
Old 24-02-2006, 8:39 AM   #3 (permalink)
Thanks mate,so they work then.
Don
Old 24-02-2006, 9:22 AM   #4 (permalink)
Thanks: Gave 1, Got 185
We bought a cheap(ish) one when my partner lived in a marginal signal area and it fixed the problem instantly.
beerhunter is offline
Old 24-02-2006, 9:51 AM   #5 (permalink)
Thanks: Gave 0, Got 11
Maplin Signal booster
I have just bought and installed a wide gain aerial from Maplin
£24.99 -the full kit
There was a amplifier fitted to the aerial and a booster signal box with ther kit.
I could not get Chhannel 5
I get a full strength signal on every channel
NJ
neiljones is offline
Old 24-02-2006, 11:37 AM   #6 (permalink)
hi i am not saying this will work for every one but it is worth a try knowing you can return it and get your money back towards a new ariel
ninegt is offline
boosters, signal
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
