Hello imacken
You can ask the same question 100 times and with this one you should get the same answer every time
Your SKY+ box has three options for Video out:
01. Composite video on SCART (SKY call it PAL in the set up menu).
02. S-Video on a 4pin Mini Din
03. RGB on SCART.
NONE of these are compatible with a YPbPr 'Component' Video Input on an AV Receiver or Display.
If SKY gave you the option of YPbPr 'Component' Out on SCART then a SCART to 3RCA cable would work - but seeing as they don't it wont.
You require an RGB2YUV converter somewhere in your system to interface SKY or SKY+ with a 3RCA 'Component' Input on an AV Receiver or Display.
The best option being the
JS Technology converters - see
http://www.js-technology.com - there are guides on the
JS web site explain RGB to YUV (YPbPr) conversion in detail.
Best regards
Joe
