AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 18-04-2001, 8:48 AM   #1 (permalink)
Duncan Harvey
Posts: n/a
Post S video from on digital boxes
Can anyone tell me whether any of the ondigital boxes can output both RGB and S video.
Ideally I'd like to send RGB to the TV from the TV Scart on the Digibox and S video to my SVHS or DVHS from the VCR scart on the digibox.
I know I can get a converter to change the RGB to S video but then this would presumably leave me with only composite output from the VCR scart.
thanks!
Duncan
Old 18-04-2001, 12:41 PM   #2 (permalink)
Post
I'm not aware of any On Digital box (or Sky Digibox for that matter), that outputs S-Video, that would be way too useful :-(
The only option I can think of is an IDTV. My Sony 28DX20 (undocumented functionality), outputs RGB from AV1 which could be connected to an RGB to S-Video adaptor. This set also allows direct coupling of RGB to the display, hence this would do what you are trying to achieve.
Unfortunately at 799+ pounds, this is a rather expensive option to solving your problem.
Perhaps some sort of scart switch box, coupled with an RGB to S-video converter would be a better option, send RGB to the TV when you want to watch that, but redirect the RGB to the converter when you want to tape something?
PeteM is offline
Old 18-04-2001, 4:08 PM   #3 (permalink)
Posts: n/a
Post
My dad has a Nokia OnDigital box & whilst in the TV & VCR set up menu it has a RGB scart to the TV & a S-video & Composite video scart to the VCR. Although it doesn't have a S-video mini din socket for TV or VCR, though. When recorded on a S-VHS tape the picture is superb.
Cheers, Neil
Old 29-04-2001, 3:47 PM   #4 (permalink)
ALanJ
Posts: n/a
Post
Two ways http://www.rgbtosvideo.com (there are others)
and at the bottom of http://forum.digitalspy.co.uk/board/...4&pagenumber=2
someone says there is a Grindig box that does...
Good luck
Old 07-07-2004, 1:02 PM   #5 (permalink)
Sky+ has S/OUT and so did the later Grundig sky boxes (From model 310/2 thru to GDS3000), but I haven't seen a Freeview box with it yet.
delessex is offline
Old 07-07-2004, 2:20 PM   #6 (permalink)
MartinImber's Avatar
Thanks: Gave 11, Got 24
Pace Twin - but then you don't need the VCR
Martin - Sony KDL46W4500, STRDB930, SLHF950 SuperBeta, Pioneer 575, Castle Pembroke, Keep, & Clydes, Pace Twin PVR, BTVision. Sony TRV33 video camera. PS3
MartinImber is offline
Old 07-07-2004, 2:39 PM   #7 (permalink)
Thanks: Gave 18, Got 22
The JS tech RGB to s-video converter has two outputs - one RGB and one S-video (the rgb just passes through). Around £75.
noidea is offline
Old 07-07-2004, 8:20 PM   #8 (permalink)
The netgem I player has RGB and S-video outputs, as far as I'm aware it can do both at the same time as it has seperate sockets for them... Not tried it though as only need RGB.
It also has USB in and digi audio out if you find these useful.
nealb is offline
Old 07-07-2004, 8:33 PM   #9 (permalink)
Emm
Emm's Avatar
Smile
Sorry, but I don't quite follow the "it can do both (RGB & S) at the same time" part.....
I thought the second scart on the I-Player was a 'pass-through'.
Quite happy to be corrected if wrong
Emm is offline
Old 07-07-2004, 9:09 PM   #10 (permalink)
Thanks: Gave 10, Got 8
I am sure the panasonic TUC30 has both RGB and SVideo out via the scart.
Azzo
azzo is offline
Old 08-07-2004, 10:56 AM   #11 (permalink)
Thanks: Gave 74, Got 68
Ondigital box? I take it you mean Freeview.
In which case go for the Pioneer 1000. It has RGB scart AND S-video SCART (on BOTH SCARTS). I use it for my SVHS vcr as well as RGB to my TV.
Kevo is offline
Old 09-07-2004, 10:41 PM   #12 (permalink)
Thomson combined DVD and freeview box.
Thomson twin freeview-tuner plus harddrive both have SVideo mini Din output. Cost - approx £200 and £250.
Port is offline
Old 10-07-2004, 6:42 AM   #13 (permalink)
Thanks: Gave 0, Got 5
Duncan Harvey
The Pioneer DBR-TF100GB does exactly what you need. Outputs RGB from TV scart and S-video from VCR scart. It is also a very good box with very good service backup. You can get it for about £71 from Richer Sounds.
JefUK is offline
boxes, digital, video
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Anyone tell the resolution difference between PAL and NTSC? Daneel Movies and The Cinema 25 08-10-2003 1:11 PM
Calibration - Digital Video Essentials tbrar Room Acoustics, Audio and Video Calibration 3 16-09-2003 9:18 PM
Digital Video IanW Video Scalers, Video Processing and Progressive Scan 7 15-11-2002 3:46 PM
36" version of the Sony KD-32NX100U? Mojo Jojo CRT Televisions 8 11-03-2002 9:54 PM
digital coaxial cable = component video?? zcaps57 DLP, LCD and D-ILA Projectors 5 09-01-2002 7:54 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
