AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 12-04-2005, 12:29 PM   #1 (permalink)
Old Digibox
I have an old Amstrad DRX100, last used in a previous house in 2001, which I was planning to use for a caravan. To test it I switched it with our current Amstrad digibox, only to find "no satellite signal". Signal strength shows nil, with occasional grey flashes. The digibox was working well when last used.
Does anyone have any ideas?
Budgie1 is offline
Old 12-04-2005, 2:51 PM   #2 (permalink)
Thanks: Gave 69, Got 314
The DRX100 was famous for tuner failure. You can get exchange tuners from MCES for £12.50 + VAT, but you have to remove the tuner (which requires quite a bit of soldering expertise) and return just the tuner to them to get this price. Alternatively you can send the box back to them and get it repaired for about £45 inc. VAT.
Nick_UK is offline
Old 12-04-2005, 4:43 PM   #3 (permalink)
Many thanks for info - I was afraid that was going to be the answer!
Budgie1 is offline
digibox
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
