AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV
LinkBack Thread Tools Display Modes
Old 02-02-2005, 2:11 PM   #1 (permalink)
drilling on tiles?
i have tiles on the outside of my house, and i was wondering if the sky engineer is able to drill through the tiles to get the dish on the wall?
andrew123 is offline
Old 02-02-2005, 2:41 PM   #2 (permalink)
richjthorpe's Avatar
Thanks: Gave 20, Got 16
What kind of tiles are they ? Ceramic ? Lime Stone ? Roof tiles ?
Sharp LC32GA3E LCD TV, HTPC, Denon AVR1601 Receiver, Canton Movie CD-1 Sub/Sat System, Digifusion FVRT100 Freeview STB, PS2.
richjthorpe is offline
Old 02-02-2005, 2:46 PM   #3 (permalink)
i'm not really sure, they look similar to roof tiles, but like i say, im not sure
Old 02-02-2005, 2:59 PM   #4 (permalink)
Starburst's Avatar
Thanks: Gave 87, Got 632
Any doubts then I wouldn't put my faith in the average SKY installer/contractor.
Might be worth talking to an authorised dealer/agent in your local area who can offer you the same "deals" from SKY but wouldn't be on a schedule and prepared to play fast and loose with your home
It may cost a little more but could bring you piece of mind.
"The Nac Mac Feegle are, well, they’re like tiny little Scottish Smurfs who have seen Braveheart altogether too many times."
Starburst is offline
Old 02-02-2005, 4:31 PM   #5 (permalink)
Thanks: Gave 0, Got 11
Hanging tiles
If the tiles have been installed properly each tile will have been fixed to a wooden baton with two nails.
There is a tile underneath the exposed tile.
If you are unlucky and crack the tile you will it very difficult to remove the broken tile and insert a new tile , that is if you can match the existing tile.
You would be advised to ring a good roof tiling company and ask their advice or find a way through by another route.
NJ
neiljones is offline
Old 03-02-2005, 4:35 AM   #6 (permalink)
Thanks: Gave 0, Got 16
We do not drill through any form of cladding. There is the risk of causing too much damage, and you do not know what is behind.
I don't do chimneys.
Bluevanman is offline
drilling, tiles
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
