01-02-2005, 10:41 AM
#1 (permalink)
Thanks: Gave 23, Got 9
Picture Setting - 16:9 or 4:3
I have a sony wega 32" widescreen tv and I have the picture settings set on my sky+ to output 16:9.
I've noticed that many programs on different channels are broadcast at different ratios. Sometimes I have the black bars on the left and right, sometimes the picture is stretched.
Is there anyway to overcome this instead of having to change the picture settings on sky+ from 16:9 to 4:3 (and vice versa) all the time.
I have searched on the forums and found information about this, and that sky+ should always be set to 16:9 and my TV should be set to 4:3, but this doesn't really help as setting my TV to 4:3 aspect ratio just narrows the screen and it looks like you're watching a 20" picture on a 32" tv!! hehe
I have 4 settings on my tv:
wide - just squashes the pic a little
zoom - stretches the pic a little
14:9 - changes the size of the pic to be 14:9 - still get black bars on either side though
4:3 - same as above but the pic is a lot smaller
Is there a way that when i get a pic in 16:9 (ie, sky news) and then change to bbc1 or itv1 (which sometimes broadcast in non 16:9) the adjustment can be made automatically without having to manually go into services/system setup/picture settings
Thanks in advance,
01-02-2005, 10:51 AM
#2 (permalink)
Thanks: Gave 7, Got 11
When I had a Sony I tended to use the Smart mode which kept the centre of the screen in roughly the right aspect and then slightly stretched the edges, not that I could tell.
You also need to have the scart option in Sky set to on as well, cannot remember if this had an affect on the screen ratio.
I currently have a Panasonic plasma which automatically adjust the picture on its auto mode.
01-02-2005, 11:33 AM
#3 (permalink)
yes.. i have the Scart set to ON and also RGB too.. but none of these seem to adjust the screen size automatically..
01-02-2005, 11:36 AM
#4 (permalink)
Thanks: Gave 3, Got 29
fully wired scart? perhaps you are missing the WSS
01-02-2005, 2:17 PM
#5 (permalink)
Fully Wired Scart? How do i know if it is or not?
Is the scart cable thats comes in the SKY+ box fully wired? As I'm not using that one currently - was using the one I previously used with orig sky box.
And what's a WSS?
Sorry for my lack of knowledge.
01-02-2005, 2:20 PM
#6 (permalink)
No problems, WSS is the widescreen switching signal that is sent down one of the pins of the scart. Best way to check is open the scart up and have a look.
01-02-2005, 3:07 PM
#7 (permalink)
"Open up the scart"?
Meaning? Just take the scart connection out from the TV or SKY+ box and have a look?
What exactly am I looking for? All pins must be there?
01-02-2005, 3:26 PM
#8 (permalink)
Pin 8 I think is used to tell the TV that a widescreen signal is being transmitted. It can also be sent via a special signal over normal transmissions but I think SKY use pin 8 on the scart. Also I reckon there will be an option in the menu of your TV for auto
01-02-2005, 3:33 PM
#9 (permalink)
OK, I'll have a check when I get home from work.. PIN 8 is in the middle?
I couldn't for the life of me find ANY options to do with screen output/aspect ratio on my TV's menu system, because I wanted to set it to "auto".
01-02-2005, 3:51 PM
#10 (permalink)
Here is a pinout for scart
01-02-2005, 4:40 PM
#11 (permalink)
Thanks: Gave 2, Got 36
Dalvin , I have a Sony set (FQ80) and a Amstrad sky+ box , the TV is set to 4:3 whilst the box is set to 16:9. So if I watch sky football it would be in WS and sky news would be in 4:3 etc etc.
however !!
The only time I get a problem is when coming out of PIP or Picture and text to a single image again, on these occasions a 16:9 pic may appear as 4:3. To resolve this I press the AV button on the remote which resets everything.
next time you get a problem try cycling through the AV channels until you get back to which ever one is connected to sky. if that doesn't work goto to
a Terrestrial channel then back to the AV channel
hope this helps
Nikon D80 w Grip, 18-135mm,70-300VR, 50 F\1.8 and SB600. Sony 40" D3000, Samsung 1080p7, Marantz SR5200, Mission 72 spk package, PS3, Wii
01-02-2005, 4:48 PM
#12 (permalink)
just checked mt scart cable.. it has all of the pins as in the diagram.. so i assume it's not this
01-02-2005, 4:50 PM
#13 (permalink)
Thanks in advance,
just reading your post I've noticed a few things .
first sky news isn't broadcast in 16:9,it's in 4:3
if you want to watch programs in their correct aspect ratio on your Sony you need to select 4:3, then sky news will be broadcast in the correct aspect ratio but when you watch say bbc1 news it will be in WS.
14:9 ratio may have to be selected by yourself, some docu channels on sky and most terrestrial channels are in 14:9 ,my Sony(FQ80) just displays them in 4:3 which means black borders all around the picture.
which model of Sony do you have ?
You could try SMART (Sony's auto setting) but that would stretch a 16:9 pic.
see my other post which may help with the WSS ?
01-02-2005, 5:00 PM
#14 (permalink)
hey mansell,
how did you set the tv for 4:3? is there a menu option? As I cannot find how to do this on mine.
01-02-2005, 5:12 PM
#15 (permalink)
I had a Sony Wega 32 crt before the Pany plasma.
I had sky set to 16:9 and scart control on.
The TV I left permanenly in"Wide" mode.
Can't remember ever having the prob's you are talking about.
(although even now bbc and itv do show some football as 4:3, which comes through sky with a bla bar either side. Nothing much you can do about that without making adjustments.But it's so rare that I ignore it.)
