Originally Posted by Chris Muriel You don't explain which way the dish would be orientated with respect to the new location.
Why put the mast above roof height when that just exposes it to more wind and rain and makes it much more inaccessible ? |
I want to pick up the satellites from 4.8E - 30W. IF there's sufficient space between the windows of each flat then there won't be an issue and I can get my dish and bracket moved over but if there isn't I don't want neighbouring flats to complain about seeing a dish out of their window that's why I thought it would be best to have the dish above roof height.
The back of my house faces roughly south and my 1.8 metre Chgannelmaster offset dish brackets are mounted on the wall - specially made heavy duty brackets that stand it off sufficiently for the dish to cover 42ºE to 45ºW.
The pole's weight is supported by some seasoned wood on top of the flat roof and a 36 volt actuator is attached to the dish.
There will be far less strain on the motor (and brackets) if you can get the roof to support the weight in this manner.
How is the pole attatched to the wood?
