Which satellites can I get on a Zone 1 Dish?
Old 05-07-2012, 5:01 PM   #1
Thanks: Gave 23, Got 33
I'm going to be moving into an apartment within the next month or two so there is no doubt going to be a limit to how large a dish I can mount. Either based on rules or just me generally being polite and not wanting a big dish outside!
The place will most likely have Dual feeds for Sky+ so I'm covered on the 28.2E front but I often watch a few bits on 19.2E and 13E that I would rather not lose.
So, if I have a south facing balcony I will probably mount a dish as neatly as I can.
It will be City Centre(ish) Manchester, and assuming I have a clear line of sight what satellites can be picked up on a Zone 1 Sky MiniDish?
Are 13E and 19.2E possible on the 43cm or 50cm Zone 1 dishes?
Also, what else can be picked up on a Zone 1 (either 43cm or 50cm)?
Old 05-07-2012, 5:12 PM   #2
Thanks: Gave 1,881, Got 4,258
13 or 19 should be each be OK on their own on a 50cm.
ant_thomas (05-07-2012)
Old 05-07-2012, 5:26 PM   #3
pedro2000uk's Avatar
Thanks: Gave 185, Got 541
With a zone 1 sky dish aimed at 13e, 28.2e - 13e - 5w is possible (33.2 degrees) & maybe a bit more ... signal strengths are stretching it for practical use on those outer lnbs but it can be done.
Old 05-07-2012, 5:32 PM   #4
19 and 13 are plenty strong enough, and I guess 23 and 9 might be too?
Old 05-07-2012, 5:38 PM   #5
Good stuff! Better get looking for a South facing balcony!
Old 05-07-2012, 6:44 PM   #6
Thanks: Gave 86, Got 441
Motorised Zone 2 Sky dish???
Old 05-07-2012, 7:42 PM   #7
Tempting, but possibly going to be too big. If I can get away with a Zone 1 then I'll definitely go for that. I can only really seem to find 43cm Zone 1 dishes rather than the larger 50cm dish which you see around (well, I do!)
Old 05-07-2012, 10:40 PM   #8
My understanding is that Zone 1 dishes are 59 by 43 and Zone 2 are 80 by 60.
Old 05-07-2012, 10:59 PM   #9
On area, Raven sky dishes are equal to the area of circles of 45cm 54cm & 64cm, (it's Raven that make the 54cm btw), the midi if you like & better for DVB-S2 in zone 1 areas IMO -
there are other makes of sky dish that vary the zone one size & their quality & other brands equal to Raven (Invacom etc)
don't think there's a zone 2 that is 80 wide - I'd buy them if there were & of decent quality, even better if they'd make one about an 80 or 85 on area.
Even on a zone one on a motor done well (they need a mod or 2) you can get over 30 satellites & over 5000 channels- .. Ideal to put 'very' high up to get big arcs.
Old 05-07-2012, 11:11 PM   #10
Zone 2 Sky Satellite Dish Quad LNB Freesat PVR HD Plus | eBay
Old 05-07-2012, 11:37 PM   #11
There is an inbetween dish which I have asked about before. I know it exists because there is one on my parents house.
There is the 43cm high Zone 1, the large Zone 2s and a dish inbetween, I'm guessing that is the 50cm high dish.
Wikipedia mentions them - Minidish - Wikipedia, the free encyclopedia
Not sure how accurate the information is though.
Old 05-07-2012, 11:38 PM   #12
What size are the Hughes dishes that are on a lot of shops and supermarkets?
Old 06-07-2012, 8:49 AM   #13
They are about 74 x 54 = 128 / 2 = 64cm on reflector area.. hence the size 64- you don't add the rim or raised area at the edge.
Old 06-07-2012, 8:57 AM   #14
I think they are about 80 on area. Did try to get hold of some a bit back- what bothers me is they go rusty on the face & so quickly & not in coastal areas- poor show there IMO. The L brackets they use are decent though- that's how an L bracket should be made - not the thin, malleable rubbish you see so much of on fleebay etc...
Old 06-07-2012, 11:31 AM   #15
Ghostleader's Avatar
Thanks: Gave 34, Got 261
Originally Posted by pedro2000uk View Post
I think they are about 80 on area. Did try to get hold of some a bit back- what bothers me is they go rusty on the face & so quickly & not in coastal areas- poor show there IMO..
Your not kidding, any that have been placed where theres rain water passing over slate before then falling on to there dish face rust up like a muther f-er.
Old 06-07-2012, 2:04 PM   #16
A rare beast I captured today:
A Raven G90 with botch job WNC $ky LNB on it.
Side view with a view of the absolutely shocking Fortec type mount, oof garbage:
Old 08-07-2012, 7:22 PM   #17
Damn, North facing balcony that isn't on the corner of the building.
I also have a feeling there's only one satellite feed inside the apartment for 28.2 rather than a twin socket. I will find out for sure in a month though.
Old 08-07-2012, 7:33 PM   #18
Sounds bad mate, ma fingers are crossed for you.
Old 08-07-2012, 8:30 PM   #19
That's not the end of the world - there's still plenty of tricks to still get just about any satellite/ multi lnb access down to the flat.
Old 09-07-2012, 12:33 AM   #20
I'm intrigued!
I will definitely find out just how restrictive the building management are with these things when I move in. And I'll no doubt be asking plenty of questions!
What are the usual methods in these situations?
Old 09-07-2012, 8:21 AM   #21
I'm intrigued!
Number one is there are European rulings & legal implications if you are prevented from having a dish that you might want to read up on ..... or without actually installing a new dish or coax run, you could use offset LNBs on the existing main system dish & use a custom bracket so that nothing actually interferes or touches the system dish & then splice into your feed with a diseqc switch after the multiswitch (if there is a multiswitch).
ant_thomas (14-07-2012)
Old 14-07-2012, 11:08 PM   #22
It seems I may actually have a corner balcony so mounting a dish looks like a possibility.
The horizontal balcony pole isn't round but flat.
There's plenty of balcony mounts for round poles. What's the best way to mount a dish on a flat balcony rail?
Old 15-07-2012, 9:45 AM   #23
Also, what's the general view on flat coax cable to bridge windows/patio doors?
Worth using?
Old 15-07-2012, 3:51 PM   #24
Thanks: Gave 22, Got 1,058
Worth using?
I use them on holidays with a portable camping dish and they are OK although I found some signal loss and an increased risk of interference from things such as DECT and WiFi devices. If possible I try to use air bricks and other forms of ventilation with normal cable if possible in semi permanent installls.
Old 30-07-2012, 12:06 PM   #25
Still looking for a suitable balcony mount.
Hopefully this picture will help (it is a bit poor though)
The purple line points south/south east. I need a mount to attach to a flat balcony rail
and here without the added drawings.
Old 04-08-2012, 2:12 PM   #26
No suggestions or am I better making a new post for the topic?
I've thought of buying two poles. One fixed to the rail with some metal or wood and bolted with some of the pole mount style fittings. Then the other fixed to that and the dish via a balcony mount.
Does that sound sensible?
Old 04-08-2012, 4:50 PM   #27
It looks like the situation defeats our expert installers!
How far out does the horizontal tube have to go?
Old 04-08-2012, 6:27 PM   #28
Not sure yet, I will find out later this week but I'm hoping less than 60cm.
Old 04-08-2012, 6:42 PM   #29
There's quite a few brackets, poles & clamp designs that could be modified to do the job- I'm not sure of the construction detail there - is that steel plate on brick edging the wall vertically? & the detail on the railing & that thin mesh don't look best to fix to easily, otherwise you could have clamped to / through it with either an L bracket or swan neck with (custom) plates to match the holes to get that standoff round the corner - a zone one AZ/EL bracket will help to add standoff.
Maybe a swan neck bolted inside the railings.. (if there's anything to bold to)
The last one I did anything like that we welded it to the railings but they weren't bothered.
Old 05-08-2012, 1:02 PM   #30
Thanks for the replies. Once I get the keys I will have a proper idea of what is required and I'll take a few photos.
What's the best place to get two suitable poles from if I go down that route? Somewhere like B&Q?
