Anybody on here got a TM5302 HD?
Old 04-07-2012, 4:47 PM   #1
Ghostleader's Avatar
Thanks: Gave 33, Got 261
Was wondering what there like, would love some user feedback. Cheers
Old 04-07-2012, 4:57 PM   #2
Thanks: Gave 1,881, Got 4,258
I had use of a 5402 recently - part good part not so good.
Old 04-07-2012, 5:04 PM   #3
Isnt that the way with everything? Lol, what didnt you like?
Old 04-07-2012, 6:22 PM   #4
pedro2000uk's Avatar
Thanks: Gave 185, Got 541
I briefly used one on an install a customer had bought by mistake - had supposed to be the TM5402HD, very different menu look- looked like a Sky HD box, has the server support to download new firmware including phantom's, the channel listing's format was different so I couldn't load it up with ours & we had to download one, which was fast to do but the sat/ channel listing was very basic, otherwise I think the same as the TM5402HD except the missing CAM & different box- not sure if something else's is different....
With that different menu look it does look like a different box from the 5402- I can see where they've gone with it & all worked OK- same sensitivity etc...
Ghostleader (04-07-2012)
Old 05-07-2012, 10:58 PM   #5
Yes, most things turn out to be good, in parts.
It's a neat looking thing and works well as Pedro found, but I didn't like the channel lists either and it uses a different recording format from the other Technos.
Old 07-07-2012, 3:24 PM   #6
Thanks: Gave 17, Got 16
The channel list is in tbn format and there are no channel settings editors available.
Old 08-07-2012, 10:05 AM   #7
thfccambs's Avatar
Thanks: Gave 816, Got 1,693
How you getting on with V+Solo? Or have you given up?
Old 08-07-2012, 10:00 PM   #8
Fine, got most of what I wanted done then my wee netbooks battery went critical mass on me, now a cant do f all, got the usb recording working before that happened luckily.
Old 08-07-2012, 10:07 PM   #9
thfccambs's Avatar
So are you pleased and are you using it to its full potential?
Old 08-07-2012, 10:17 PM   #10
Unfortunately not, but hey ho, do you know if I can get the Sundek DVB-S2 USB stick working wothout the need for a pc, I seen one on German Amazon for a good price.
Old 09-07-2012, 7:33 PM   #11
thfccambs's Avatar
Sorry use an internal HD on my V+
What problems you having?
