Originally Posted by gilzeans head pro dave i have just discovered a blue sky viewing card in the box,doesnt seem to have any effect,also noticed the epg is the old listings,not the newish one i had when i subscriped to sky a couple of years ago! bought the box from e bay and the guy lived in northern ireland so you could be right. |
Right, the box has been out of use for a LONG time.
Ignore the card for now, it may or may not be of use. Take it out of the box for now.
You need to do a forced software update to get the "new" EPG.
Unplug the box from the mains, press and hold the backup button on the top, keep holding the button and plug the mains in. Keep holding it until all 4 lights on the front come on and a message appears on the tv "updating software....."
Go and have a cup of tea and come back in 15 minutes and it should have updated and should have the new EPG.
Then see what channels you have.
Then put the card back in and see how it changes (BBC1 and ITV regions will change) then decide if you prefer it with or without the card.
You just may be very lucky and find the card enables recording, certainly worth a try to see.
